division problem 500000 / 133
Results 1 to 6 of 6
    Sep 2006
    Default Re: division problem 500000 / 133
    I am using the 16F88 chip..
    tried your code but shows 65535 on LCD
    K
    Here is a snipit form a program I use and it works great:
    CALCF_C: 'CALCULATE DEG.F and DEG.C for LM 95231 TEMPERATURE SENSOR READING
    CALCF:
    SCRATCH = TEMPREAD * 1000
    TEMPF = DIV32 17777
    TEMPF = TEMPF * 10
    TEMPF = TEMPF + OFFSET
    CALCC:
    TEMPC = DIV32 32
    Just make sure you don't have any interrupts going on when using DIV32.
    I also think your problem may be that you are using a variable after the DIV32 keyword. Try entering the constant value and see if that doesn't work.
    EN82fn
    Sep 2006
    Dummy = 500*1000 ' Produce intermediate result of 500000
    Result = DIV32 133
    lcdout $FE,2, "Duty:", dec Result
    ... still getting 65535 as output
    Thats all I have in the program, no interrupt nothing else !
    then I initialized my parameters this way:
    a var word
    b var word
    a= 500
    b = 1000
    Dummy VAR word
    Result VAR WORD
    Divider con 145
    Dummy = a * b ' Produce intermediate result of 500000
    Result = DIV32 133
    and its now working.. Dummy doesnt like numbers
  1. // Division Operator
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 9th September 2011, 15:27
  2. What is wrong with this division?
    Last Post: - 5th March 2010, 18:34
  3. Division by 0
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 4th August 2007, 02:11
  4. Division with some decimal
    By Darklakebridge7 in forum mel PIC BASIC Pro
    Last Post: - 10th May 2007, 07:41
  5. division
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 28th March 2006, 17:26
