Mikro Elektronika Basic and PBP
Results 1 to 6 of 6
    Default Re: Mikro Elektronika Basic and PBP
    Of course you can run PBP code on the EasyPIC7 board. The board and whatever PIC you put on it doesn't know the difference.
    What you can't (obviously) do is use THEIR (MikroE's) integrated development environment and debugger, apart from that it works just fine. Write your code, compile and assemble with PBP/MPASM and use MikroE's programmer application to transfer the .hex file to the PIC on the board - no problems what so ever.
    Jun 2011
    Indian Harbour Nova Scotia
    Henrik responded as I would have. Yes, you can use the Mikro board for development by sending the hex file (from the PBP compiler) to it. I have both systems on my desk and will use both. I was just trying to say that PBP is not necessarily a low-end compiler or language, that it surpasses compilers that are more sophisticated.
    Think of it this way: the Volkswagen (PBP) will get you to the store just as quick as the Jaguar (Mikro Basic) where you can pick up the same groceries. Of course with the Jag you could pick up girls as well! If I was doing what I do for WORK, I would go with the more sophisticated, full featured, strict rules Mikro Basic, but for quick projects, nothing beats PBP.
    Some of the reasons I purchased Mikro Basic is its support for long words, floating point calcs, documentation like photos, videos, text as part of the project, software simulator and project statistics.
  1. Replies: 3
    Last Post: - 5th September 2014, 06:20
  2. Moving from Basic Stamp and MIKROE basic to PicBasic PRO
    Last Post: - 6th March 2013, 05:27
  3. Indexer not indexing...a basic PBP problem??
    By jellis00 in forum General
    Last Post: - 24th March 2009, 16:53
  4. pbp pro versus oshon or bascom basic
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2006, 00:49
  5. Replies: 5
    Last Post: - 17th January 2006, 19:26
