Cannot wake from SLEEP
Results 1 to 6 of 6
    Dec 2007
    Finland
    Default Re: Cannot wake from SLEEP
    Yes it is. Below is part of PIC18F4620.PBPINC from device -folder.
    ;  The #CONFIG block is passed directly to the asm file, but PBP will replace it
    ;  automagically with the contents of a user-defined #CONFIG block if one is
    ;  found in the PBP source program.  There is no need to edit or comment this
    ;  block in this file.  Simply copy it to your source program and edit it there.
            __CONFIG    _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    This is example that I have used with PIC18F4520 and it might be just fine for you too. If not, then change according to your needs.
    At least sleep & nap are working OK, also with interrupt. Check right parameters for CONFIGS from link that I sent earlier (credits to Demon).
        __CONFIG    _CONFIG1H, _OSC_INTIO67_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOREN_OFF_2L
        __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
        __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
  1. Wake from sleep with USB Interrupt
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 13th January 2013, 01:59
  2. 16F690... How to wake from sleep?
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 5th July 2011, 23:07
  3. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 05:33
  4. wake up from sleep
    Last Post: - 31st August 2007, 18:09
  5. ? about sleep/wake on pin change and WDT
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 26th January 2007, 00:25
