16F1825 CONFIG1 AND CONFIG 2 questions
Results 1 to 8 of 8
    Feb 2012
    PERTH AUSTRALIA
    Default Re: 16F1825 CONFIG1 AND CONFIG 2 questions
    Hi Dave,
    i know this chip well now and i can read the data sheet,
    Config word naming conventions for each option on each chip are a PBP based , not chip datasheet one , although they relate to each option on the chip
    I have yet to find the reference in the manual for each option PBP assigns per option. but if you know of such , please show a link if possible
    Debug of bit value of 1 is noted in the data sheet .
    The real focus of the question was to find the correct PBP naming of the options listed for the 4 i cannot find for PBP3.
    Sheldon
    ;----- CONFIG1 Options --------------------------------------------------
        __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    ;----- CONFIG2 Options --------------------------------------------------
        __config _CONFIG2, _LVP_OFF & _BORV_HI & _STVREN_ON & _PLLEN_ON & _WRT_OFF
  1. Config & Oscon settings 16F1825
    Last Post: - 9th July 2020, 17:18
  2. 16F886 (illegal opcode CONFIG1)
    By MOUNTAIN747 in forum General
    Last Post: - 29th May 2015, 19:35
  3. Battery voltage monitoring for use on 16F1825
    Last Post: - 23rd April 2013, 14:57
  4. Weird PWM Behaviour on 16F1825
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 26th October 2012, 21:59
  5. Interrupt On Change Question on 16F1825
    Last Post: - 23rd August 2012, 05:05
