Obstacle Avoidance
Results 1 to 3 of 3
    Unhappy Obstacle Avoidance
    pls I urgently need help with my code. I am using Amicus18 and the language is BASIC. I have used the ADIn to calculate the voltages for the four IR sensors and converted to distance by plotting the Distance/voltage curve and using the line equation to determine the distances with the assciated voltages but I have tried many days to let the robot appraoch an object and stop but it just can't stop. The code I write for that portion is If D_L1 >=15 Then turn left : ELSEIF D_R1>=15 Then turn left : ELSE : GoTo forward. What do I have to do to get it stop. It can reverse, it can turn left and right but it cannot stop when it gets to an obstacle. Thank you for your help.
    Default Re: Obstacle Avoidance
    If you are using the free compiler for the Amicus 18 go here
    http://www.myamicus.co.uk/
    If you are using Pic Basic Pro then post your code.
    stive951's Avatar
    stive951 Guest
    I cannot get this example code to compile - syntax error after step 2 . I tried several different versions of the statement, but no luck.
  1. Line Following, Obstacle Avoiding , and Victim Finding
    By cryptex in forum mel PIC BASIC Pro
    Last Post: - 18th June 2011, 16:34
