Pic Basic Pro and C#
Results 1 to 10 of 10
    Dec 2012
    Tennessee
    Default Re: Pic Basic Pro and C#
    using your C code and a serial port to send receive data from the PIC, its like communicating with 2 computers via null modem cable in the old days. I use VB.net and its got a prebuilt in control for serial communication, if your using visual c/c++ it should have that too. to communicate with PIC USB Ports you should have to use a HID.dll file to communicate I think. Not sure how to do this on C, but in microcode studio it has a HID maker.
    But I would try just interfacing with the PIC via serial port to get the understanding and your program in c working first then change the type of communication.
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    May 2011
    aha
    thx for answer now I understand how that works and it is clear to me now. So program created in C++ or C# will send info to USB, and program for PIC will register that info from USB and do what ever he is program to do.
    Quote Originally Posted by CipiCips View Post
    aha
    I would start by sending out serial from a PIC programed with compiler of your choice to a PC serial port and run HyperTerminal which is found in windows in the start menu under accessories > communications.
    The sent text will display on the terminal screen.
    Hyperterminal can also be configured to send keystrokes back to the PIC with a receive routine for example to blink an LED if RX is "1".
    This is a major cool factor for a beginner programmer!
    Norm
  1. More Pic basic pro maths help.
    Last Post: - 10th February 2011, 07:09
  2. serial interface pic 18f452 using pic basic pro
    By syed ahmed in forum Serial
    Last Post: - 16th May 2010, 06:46
  3. Replies: 5
    Last Post: - 17th January 2006, 20:26
  4. Pic Basic Pro Syntax
    By Finn in forum mel PIC BASIC Pro
    Last Post: - 26th January 2004, 19:07
  5. help pic basic pro
    By f6ggy in forum mel PIC BASIC Pro
    Last Post: - 29th September 2003, 01:55
