Debugin conditional routine
Results 1 to 4 of 4
    Default Re: Debugin conditional routine
    You can only have 1 WAIT() at a time.
    But you can do it manually ... nothing "Tricky".
    If the variables for each preamble are the same you could ...
    Wait4Preamble:
        debugin [preamble]
        IF (preamble != %10001000) AND (preamble != %01001000 ) THEN Wait4Preamble
        debugin [mydata2, mydata3]
    Or, if the variables are different ...
    Wait4Preamble:
        debugin [preamble]
        IF preamble = %10001000 THEN
            debugin [mydata0, mydata1]
            IF preamble = %01001000 THEN
                GOTO Wait4Preamble
    Hello DT,
    Thanks for the info. I did think of doing that, for whatever reason I must have over throught it. I was concerned about missing the next byte. It just ocurred to me that the wait state is not all that much different than a manual loop.
    Thanks!
    Nick
    Aug 2003
    That wait state likely is different actually, and happening at a low level.
    It should be fast enough to catch the next byte,
    You would find if you had to check for many possible different values, you'd run out of time.
    How long you have depends on "character pacing", and nothing to do with baud rate.
  1. Conditional compilation
    By ro37bis in forum mel PIC BASIC Pro
    Last Post: - 11th July 2011, 00:02
  2. help with PIC16F628 conditional program
    By joseph in forum mel PIC BASIC Pro
    Last Post: - 5th July 2010, 14:54
  3. Conditional Defines?
    Last Post: - 21st June 2010, 23:08
  4. Which conditional expression is faster?
    By RussMartin in forum General
    Last Post: - 15th February 2009, 20:21
  5. Conditional Compilation
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 21:29
