Usb to serial converter with pic18f
Results 1 to 3 of 3
    Sep 2009
    Default Usb to serial converter with pic18f
    I'm working on redesign device which have PL2303 and few passives components, and transistors. My idea is to replace PL2303 with PIC18F and to add more functionality.
    But I do not know how to send serial port settings(baud rate, parity, etc) from PC to PIC.
    Does any one have idea where to start? Custom drivers for windows
    Sep 2009
    Default Re: Usb to serial converter with pic18f
    Update:
    Just found that microchip usb stack 2.x support notification system when baud rate is changed on host.
    Is there any way to implement that on existing cdc example for PBP?
    Sep 2009
    I run into same issue, again. I needed to create full serial port emulator, like FT232, and to do some other things with pic.
    I spent almost a week, trying to get C to work, and decided to give PBP another try.
    This time with good result.
    To get baud rate, parity and stop bits from original CDC demo, use this code
        BaudRate var long BANKA SYSTEM
        StopBits Var	Byte BANKA SYSTEM ;0=1 stop bit, 2=2 stop bit
        ParityType Var	Byte BANKA SYSTEM
        DataBits Var	Byte BANKA SYSTEM
    Main: ' original code from CDC example
        GOSUB GetLineCoding 'get baudrate etc... Should do that regularly and check if anything is changed
    GetLineCoding:
    asm
     	movlb	high _USBMEMORYADDRESS	; Point to proper bank
    	movf	line_coding + dwDTERate, W
    	movwf   BaudRate
        movf	line_coding + dwDTERate + 1, W
    	movwf   BaudRate + 1
    	movf	line_coding + dwDTERate + 2, W
    	movwf   BaudRate + 2
    	movf	line_coding + dwDTERate + 3, W
        movwf   BaudRate + 3
    	movf	line_coding + bCharFormat, W
    	movwf   StopBits
    	movf	line_coding + bParityType, W
        movwf   ParityType
    	movf	line_coding + bDataBits, W
    	movwf   DataBits
    endasm
  1. pic18f driving usb printers
    By ephesus in forum USB
    Last Post: - 22nd March 2012, 03:07
  2. USB certification PIC18F
    Last Post: - 25th June 2010, 20:37
  3. serial to usb converter
    By nicjo in forum Serial
    Last Post: - 18th September 2008, 00:52
  4. FTDI USB to Serial converter chip
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2007, 04:30
  5. Serial to USB converter
    By jrt4fun in forum USB
    Last Post: - 8th August 2005, 16:14
