ibutton ds1990 dallas
Results 1 to 11 of 11
    davleo's Avatar
    davleo Guest
    Default ibutton ds1990 dallas
    I would like to know, if somebody know how to read the serial num of ibutton ds1990 dallas, with a 16fxxx . All the information a found was in asm
    thx
    ogranadino's Avatar
    ogranadino Guest
    Talking help for u.
    programm...
    #include <touch.c>
    void main() {
    BYTE buffer[8];
    BYTE i;
    printf("\r\nWaiting for a touch device...\r\n");
    while (TRUE) {
    while(!touch_present()) ;
    delay_ms(200);
    if(touch_present()) {
    touch_write_byte(0x33);
    for(i=0;i<8;++i)
    buffer[i]=touch_read_byte();
    //you need to use this lib
    //// Dallas Touch Driver ////
    //// present = touch_present() Issues a reset and returns TRUE ////
    //// if the touch device is there. ////
    //// data = touch_read_BYTE() Reads one BYTE from a touch device. ////
    //// ok = touch_write_BYTE(data) Writes one BYTE to a touch device ////
    //// and returns TRUE if all went OK. ////
    //// A FALSE indicates a collision with ////
    //// another device. ////
    //// Derivative programs created using this software in object code ////
    //// form are not restricted in any way. ////
    #ifndef TOUCH_PIN
    #define TOUCH_PIN PIN_B0
    #if defined(__PCH__)
    #bit TOUCH_PIN_BIT = 0xF8A.0
    #else
    #bit TOUCH_PIN_BIT = 6.0
    #endif
    #endif
    BYTE touch_read_byte() {
    BYTE i,data;
    for(i=1;i<=8;++i) {
    output_low(TOUCH_PIN);
    delay_us(14);
    output_float(TOUCH_PIN);
    delay_us(5);
    shift_right(&data,1,input(TOUCH_PIN));
    delay_us(100);
    return(data);
    BYTE touch_write_byte(BYTE data) {
    BYTE i;
    for(i=1;i<=8;++i) {
    delay_us(10);
    if(shift_right(&data,1,0)) {
    output_high(TOUCH_PIN);
    delay_us(10);
    if(!TOUCH_PIN_BIT)
    return(0);
    } else {
    delay_us(10);
    if(TOUCH_PIN_BIT)
    return(0);
    delay_us(50);
    delay_us(50);
    return(TRUE);
    BYTE touch_present() {
    BOOLEAN present;
    delay_us(500);
    delay_us(5);
    if(!input(TOUCH_PIN))
    return(FALSE);
    delay_us(65);
    present=!input(TOUCH_PIN);
    delay_us(240);
    if(present)
    return(TRUE);
    return(FALSE);
    luck.. touch the ds1990 or ds1991 whit pin RB0(B0), and the other side to ground...
    best regards
    oscar from chile.
    davleo's Avatar
    davleo Guest
    thanks oscar
    There is a more easy way (use 1-wire) personal message me if you like more info
    Feb 2004
    Germany
    It is as simple as:
    ' Read iButton Family Code & Serial Number
            TempA var byte[8]
            iButton Var PortB.0 ' iButton connected to PortB.0
            OWOUT iButton,1,[$33] ' Issue Read ROM command
            Pause 100
            'Read 64 Bits (8 Bytes) into Array TempA
            OWIN iButton,0,[TempA[0],TempA[1],TempA[2],TempA[3],TempA[4],TempA[5],TempA[6],TempA[7]]
    For Reference see DS1990 Datasheet
    regards
    Ralph
    Quote Originally Posted by nl2ttl
    why? it is not the place to share our code & knowledge? it's a military secret?
    Feb 2004
    Germany
    Quote Originally Posted by mister_e
    Steve, it's like with binary,
    There are only 10 types of people
    ... those who do share code,
    and those who don't
    regards
    Ralph
    Well, i can share my code, and no problem at all but in the past i see so many poeple place mess of code, and at that moment the one how asked has already fixed it.
    Next time i post ie directly no hard feelings :P
    ogranadino's Avatar
    ogranadino Guest
    Default Crc
    I would like to know, if somebody know how to calculate the CRC of ibutton ds1990 dallas, with a 16fxxx . All the information a found was in asm
    thanks.
    ogranadino's Avatar
    ogranadino Guest
    Default thanks
    thanks steve.
  1. Dallas CRC8 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 8th May 2018, 19:07
  2. Dallas IButton 1990 Presence pulse
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 15th August 2008, 23:04
  3. dallas ibutton to pics
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 13:55
  4. Dallas 1-wire search Routine
    By jimbab in forum Code Examples
    Last Post: - 7th April 2006, 17:14
  5. Dallas DS1994 iButton CLOCK
    By NavMicroSystems in forum Code Examples
    Last Post: - 29th September 2004, 23:19
