Long desired operation - PIC + Wifi. Help please
Results 1 to 9 of 9
    Default Re: Long desired operation - PIC + Wifi. Help please
    If you are comfortable with SPI then the MRF24WB0MA looks good.
    The MRF24WB0MA is just a radio with hardware encryption built-in.
    It does not have a TCP/IP stack.
    You have to implement the TCP/IP stack in your program.
    The TCP/IP stack is only available in the C language.
    It is not available in PBP.
    If you are just starting out, the MRF24WB0MA would be your worst choice.
    Dec 2005
    You might look at Roving Network's devices. Microchip bought them about 8-9 months back. Their modules are very cost effective.
    http://www.rovingnetworks.com/products/Wi_Fi_Modules
    The MRF24WB0 has a companion chip called MCW1001 which has the TCP/IP stack built in and does the "heavy lifting". MikroE has their Wifi Plus module which is a module with these two parts. I've had one for a while but haven't got around to try it out yet. The Roving Network modules looks really nice too and most of them are cheaper than the Wifi Plus so I don't know....
  1. PIC && WiFi suggestions
    By rdxbam in forum General
    Last Post: - 26th July 2011, 18:40
  2. Wifi & PIC
    Last Post: - 26th December 2010, 04:16
  3. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 04:19
  4. Must reset PIC to get correct operation?
    Last Post: - 2nd June 2006, 02:59
