Long desired operation - PIC + Wifi. Help please
Results 1 to 9 of 9
    Default Re: Long desired operation - PIC + Wifi. Help please
    Look at the similar threads listed at the bottom, there are already several threads about PIC-WIFI. Here's one:
    http://www.picbasic.co.uk/forum/showthread.php?t=10074
    SEARCH is your friend.
    Jan 2010
    Thanks. It would be easier for me if I know what to look for. Is it wifi to serial? Before I go there, do these modules have their own wifi ID which I should connect to to talk my PIC OR they can connect to my wifi network? How is that accomplished? What features I should look for apart from serial capability? Using these modules, can I talk to my PIC from anywhere or only when I am connected to the same wifi network? Will my PIC also be able to send data over wifi to the outside world? I have many questions of these types which may be simple for someone who knows but challenging for me at this stage.
    http://www.picbasic.co.uk/forum/showthread.php?t=14912
    I can only talk about the Connect One modules. The wifi module will connect to your access point just as a PC does. Configure it to look for the SSID and give it the passkey.
    I have not used these very much to talk to the MCU from the net but they do have a function called Serial Net for this.
    http://www.connectone.com/?page_id=310
    You can use these as a web page server, small, but they only work on port 80. This may have changed though. If I recall correctly, the Serial Net mode can use other ports.
    They work very well for sending data via email or FTP.
    Jan 2010
    thanks. I read about connect one modules mentioned above. I also came across MRF24WB0MA which seems quiet cost effective. Any Idea if this would be fit to start with?
    If you are comfortable with SPI then the MRF24WB0MA looks good.
    The MRF24WB0MA is just a radio with hardware encryption built-in.
    It does not have a TCP/IP stack.
    You have to implement the TCP/IP stack in your program.
    The TCP/IP stack is only available in the C language.
    It is not available in PBP.
    If you are just starting out, the MRF24WB0MA would be your worst choice.
    Dec 2005
    You might look at Roving Network's devices. Microchip bought them about 8-9 months back. Their modules are very cost effective.
    http://www.rovingnetworks.com/products/Wi_Fi_Modules
  1. PIC && WiFi suggestions
    By rdxbam in forum General
    Last Post: - 26th July 2011, 17:40
  2. Wifi & PIC
    Last Post: - 26th December 2010, 03:16
  3. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 03:19
  4. Must reset PIC to get correct operation?
    Last Post: - 2nd June 2006, 01:59
