Hi Ken,
Let's have a look at your config statements please . . . Are you using internal osc on the breadboard too?
Sometimes if PICs power up too slowly they flounder a bit before starting, also backfeeds make for strange behavior. . .
Hi Ken,
According to the PBP3 manual LCDOUT command: "A program should wait for up to half a second before sending the first command to
an LCD. It can take quite a while for an LCD to start up". I don't see the wait time in your code.
Is it possible to have full code, schematic and some part numbers of major components?
I thought that pause should be in your main loop. You'd do all the stuff and get the data ready for transmit, pause 500 and then send it to the LCD. I assumed that time was needed to get the LCD to warm up once your main loop starts not simply after the chip is powered up.
I'd like to know chip as I'm wondering if OSCCON statement is correct.
Hi, the Holy Squad ...
I found this was overall a bit strange ...
so, rewrote the program and tested it with ISIS ... ( note it works fine NOW ... with ISIS !!! )
just change the DEC3 and DEC4 ( lcdout section ) into DEC ...
and, please, tell me your results ...
There's something I really do not understand here ...Alain
Code:'**************************************************************** '* Name : UNTITLED.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 10/05/2013 * '* Version : 1.0 * '* Notes : * '* : * '**************************************************************** INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language OSCCON = %01101000 ' 16F 88 4 Mhz ... for those who didn't find it ... ( LOL ) DEFINE OSC 4 DEFINE LCD_DREG PORTB ' Set LCD Data port DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus DEFINE LCD_RSREG PORTA ' Set LCD Register Select port DEFINE LCD_RSBIT 2 ' Set LCD Register Select bit DEFINE LCD_EREG PORTA ' Set LCD Enable port DEFINE LCD_EBIT 3 ' Set LCD Enable bit DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) DEFINE LCD_LINES 2 ' Set number of lines on LCD DEFINE LCD_COMMANDUS 2500 DEFINE LCD_DATAUS 250 DEFINE CHAR_PACING 2000 pause 1500 LCDOUT $FE,1 ' Define ADCIN parameters Define ADC_BITS 10 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 50 ' Set sampling time in uS DEFINE CCP1_REG PORTB DEFINE CCP1_BIT 0 CMCON = 7 CVRCON = 0 ANSEL = %00000011 ' set AN0, AN1 as analog, others to digital ADCON0 = %11000001 ' Configure and turn on A/D Module ADCON1 = %10000000' Set PORTA analog for ten bit ADC PORTA = 0 PORTB = 0 TRISB = %01000010 TRISA = %00000111 DutyCycle var word OldDutyCycle Var Word Frequency var word OldFrequency VAR word WHILE 1 'ADCON0.2 = 1 'Start Conversion pause 20 ADCIN 0, DutyCycle 'Read channel PORTA.0 Duty Cycle ADCIN 1, Frequency 'Read channel PORTA.1 Frequency 'Frequency = Frequency + 245 'DutyCycle = DutyCycle/4 IF Frequency <> OldFrequency OR DutyCycle <> OldDutyCycle THEN lcdout $FE,2, "DutyCyc: ", dec3 DutyCycle/4 lcdout $FE,$C0, "Frequen: ", dec4 Frequency+245 pause 100 HPWM 1,DutyCycle/4,Frequency+245 'channel, dutycycle, frequency OldFrequency = Frequency OldDutyCycle = DutyCycle pause 20 ENDIF WEND END
Nothing Strange .... Just Shame on me
PS: F....ing Timeout !!! I begin to think just a Lester's trick to get more posts on the forum counter ...![]()
Thanks for he program Alain, way better then mine
I changed breadboard, redone the circuit and it works !! go figure....
I tried opersting at 1Mhz to get slower output frequency. used
OSCCON = %01001000 '
but DEFINE OSC 1 do not work.
Do I have to do something else ?
K
