Slow starting up
Results 1 to 35 of 35
    Sep 2006
    Default Slow starting up
    hello,
    Not sure when I should put this...
    I have a program working 100% on the breadboard.
    I made a prototype board (soldering) , use the same chip and put in the socket of the prototype board. guess what.. its takes about 8 to 40 seconds to get running and showing values on the LCD..
    ..sometimes it will show only half the LCD screen for a couple of seconds then will show all what is suppose to show.
    First, it should take just 1 second to show the info on the LCD
    Second, like I said its the same chip.. put it back on the breadboard and it works.... Same value 10k MCLR,
    Anybody had this issue before ???
    I 'd rather it not be working instead of this...
    K
    Sep 2006
    Default Re: Slow starting up
    I will post the code, because I think that might be issue here... I used another PIC from a previous project and its working ..
    INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
    OSCCON = %01100000 '4 Mhz
    CMCON = 7 : ADCON1 = 7
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTA ' Set LCD Register Select port
    DEFINE LCD_RSBIT 2 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTA ' Set LCD Enable port
    DEFINE LCD_EBIT 3 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    pause 1500
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    DEFINE CCP1_REG PORTB
    DEFINE CCP1_BIT 0
    ANSEL = %00000010 ' set   AN1  as analog, others to digital
    ADCON1 = %10000010 ' Set PORTA analog for ten bit ADC
    'ADCON0 = %00000001 ' Configure and turn on A/D Module
    TRISB = %01000010
    TRISA = %00000111
    DutyCycle var word
    Frequency  var word
    Mainloop:
    ADCON0.2 = 1			'Start Conversion
    pause 20
    ADCIN 0, DutyCycle 'Read channel PORTA.0 Duty Cycle
    ADCIN 1, Frequency 'Read channel PORTA.1 Frequency
     Frequency = Frequency + 245
     DutyCycle = DutyCycle/4
    lcdout $FE,1, "DutyCycle: ", dec DutyCycle
    lcdout $FE,$C0, "Frequency: ", dec Frequency
    HPWM 1,DutyCycle,Frequency 'channel, dutycycle, frequency
    pause 20
    goto Mainloop
    Solder-less breadboards have a ton of capacitance, between traces, probably need some on the crystal to get reliable OSC start . . . also add caps to LCD power pins. If you're using a resonator use HS not XT in your configs?
    Sep 2006
    I have a 1uF cap, and using 4mhz internal clocking.
    may preset the outputs levels ...
    and explicitly write the chip config ...
    Sep 2006
    I have an earlier version of that program, ( and no I changed it since) and that version work, meaning does not have this problem.
    I guess something is wrong with the code..
    K
    Ok, Ken ...
    as you always know where the problem is ... I wish you a nice day !
    Sep 2006
    ''as you always know where the problem is ...'' where is that coming from ?!!
    K
    I can only assume he is referring to your comment that the problem must be in the code.
    Sep 2006
    yep, thats why I posted the code. I might of changed something in the code that made it slow, because My older chip (which i dont have the code now) dont have a slow start. only this one. Maybe its the chip itself. i cannot use another chip, I dont have one and I dont want to erase the working one.. i'll keep it as my reference.
    K
    Sep 2010
    Las Vegas, NV
    What chip are you using? Could you add a schematic also please?
    Dec 2012
    Tennessee
    I had a issue with time using a 16F877 chip the first time, I tried setting it to internal OSC in the fuse section of my programmer software, Apparently i did something wrong because it took about 1 minute for my lcd to come on, and even though my longest pause was 1 second, the fastest updates on my lcd were about 30 seconds, talk about problems with adc and such, I gave up on it at the time and havent used a 877 since. Im sure its something simple, if your using a external crystal make sure its got good connections to board, if its shorted or open perhaps the chip is changing to internal osc to prevent damage? not sure logically as long as your board is wired identical to the breadboard connections there is no logical reason it should not fuction the same... with the exception of capacitance, resistance, and inductance inherant in using jumper wires and mechanical connections. this is not usually a problem on breadboards. likely your problem would be in reverse, it works on PCB but not on breadboard if that was the issue.
    Perhaps, based on what you have other than your PIC, perhaps leave the PIC off the PCB and check continuity on buttons, diodes, etc.
    and dont forget to take a break or work on some other PIC project for a bit. Sometimes I get into bulldozer mode when I have a problem, 12 hours later im fruserated and tired and its still not working... but a break or playing with some other code makes me relax a bit and sometimes the fix just comes when your not trying so hard.
    when I design PCB's it helps sometimes to print it out and the schematic and compare and mark off parts and connections, see if your missing something or have something in the wrong location.
    Hope you figure it out.
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Hi Ken,
    Let's have a look at your config statements please . . . Are you using internal osc on the breadboard too?
    Sometimes if PICs power up too slowly they flounder a bit before starting, also backfeeds make for strange behavior. . .
    Sep 2010
    Las Vegas, NV
    According to the PBP3 manual LCDOUT command: "A program should wait for up to half a second before sending the first command to
    an LCD. It can take quite a while for an LCD to start up". I don't see the wait time in your code.
    Is it possible to have full code, schematic and some part numbers of major components?
    Quote Originally Posted by AvionicsMaster1 View Post
    ...I don't see the wait time in your code.
    Pause 1500 after defines.
    Maybe it should be moved after all registers are set?
    Sep 2010
    Las Vegas, NV
    I thought that pause should be in your main loop. You'd do all the stuff and get the data ready for transmit, pause 500 and then send it to the LCD. I assumed that time was needed to get the LCD to warm up once your main loop starts not simply after the chip is powered up.
    I'd like to know chip as I'm wondering if OSCCON statement is correct.
    Hi, the Holy Squad ...
    I found this was overall a bit strange ...
    so, rewrote the program and tested it with ISIS ... ( note it works fine NOW ... with ISIS !!! )
    just change the DEC3 and DEC4 ( lcdout section ) into DEC ...
    and, please, tell me your results ...
    There's something I really do not understand here ...Alain
    '*  Notice  : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 10/05/2013                                        *
    OSCCON = %01101000 ' 16F 88 4 Mhz ... for those who didn't find it ... ( LOL )
    pause 1500
    LCDOUT $FE,1
    DEFINE CCP1_BIT 0
    CMCON  = 7
    CVRCON = 0
    ANSEL  = %00000011 ' set   AN0, AN1  as analog, others to digital
    ADCON0 = %11000001 ' Configure and turn on A/D Module
    ADCON1 = %10000000' Set PORTA analog for ten bit ADC
    PORTA = 0
    PORTB = 0
    TRISB = %01000010
    TRISA = %00000111
    DutyCycle       var word
    OldDutyCycle    Var Word
    Frequency       var word
    OldFrequency    VAR word
    WHILE 1
    'ADCON0.2 = 1			'Start Conversion
    pause 20
     'Frequency = Frequency + 245
     'DutyCycle = DutyCycle/4
    IF Frequency <> OldFrequency OR DutyCycle <> OldDutyCycle THEN
        lcdout $FE,2, "DutyCyc: ", dec3 DutyCycle/4
        lcdout $FE,$C0, "Frequen: ", dec4 Frequency+245
        HPWM 1,DutyCycle/4,Frequency+245 'channel, dutycycle, frequency
        OldFrequency = Frequency
        OldDutyCycle = DutyCycle
        pause 20
    WEND
    Nothing Strange .... Just Shame on me
    PS: F....ing Timeout !!! I begin to think just a Lester's trick to get more posts on the forum counter ...
    Sep 2006
    Thanks for he program Alain, way better then mine
    I changed breadboard, redone the circuit and it works !! go figure....
    I tried opersting at 1Mhz to get slower output frequency. used
    OSCCON = %01001000 '
    but DEFINE OSC 1 do not work.
    Do I have to do something else ?
    K
    Yes ...
    Urgent to learn your Holy Manual !!!
    Sep 2006
    Hey
    belive me I had a look..
    page 278 and 279 of the manual states the define and OSCCON values.
    The datasheet talks about the OSCCON value which I set. But the define OSC 1 Mhz do not work. Lowest it will go is 4Mhz.
    Datasheet stipulates internal oscillation can go as low as 31khz...
    Sep 2010
    Las Vegas, NV
    I'd like to see the rest of your code but is OSCCON = %01001000 correct? Shouldn't it be OSCCON = %01001110? I'm assuming you're using an internal oscillator, should be stable and it should be used as system clock. I don't know why 4Mhz worked but, if that's all you changed between compiles, then try that.
    This is for a 16F88 and is on page 40 of the datasheet.
    Sep 2006
    ya that works, that bit at position 1. Ithink that did it. thanks
    Bits 0 through 3 of OSCCON are read only?
    Sep 2006
    Actually it compiles , but after careful testing, the frequency is all over the place when using only OSCCON = %01001110..
    Hi All. After reading this thread, it made me look at something I now don't understand. I've been using this table for years for 'F819 and 'F88. But when you convert the decimal numbers to binary, the bits don't match the table in the datasheet. When you pick the bits and convert to decimal, they don't match the table. Does anyone know why? Thank you.
    'osccon values for 16f818/819:
    'OSCCON = $00 'for 31.25 khz
    'OSCCON = $10 '125khz
    'OSCCON = $20 '250khz
    'OSCCON = $30 '500khz
    'OSCCON = $40 '1mhz
    'OSCCON = $50 '2mhz
    OSCCON = $60 '4mhz 'set int osc to 4mhz
    'OSCCON = $70 '8mhz
    You can change READ-ONLY registers all you want. The PIC will just ignore your requests at best.
    As you can see, the 4MHZ is uncommented. If you convert the number to binary, it doesn't match the osccon bits in the datasheet when you select 4MHZ. Same with the reverse, select the 4MHZ bits in the datasheet, convert to decimal and it doesn't match the table. Yet, the numbers in the table do work.
    'OSCCON = $40 '1mhz
    'OSCCON = $50 '2mhz
    'OSCCON = $70 '8mhz
    These hex values match the 16F818 as expected.
    from your code..........................
    'OSCCON = $40 '1mhz
    'OSCCON = $50 '2mhz
    'OSCCON = $70 '8mhz
    from the data sheet.....................
    bit 6-4 IRCF2:IRCF0: Internal Oscillator Frequency Select bits
    111 = 8 MHz (8 MHz source drives clock directly)
    110 = 4 MHz
    101 = 2 MHz
    100 = 1 MHz
    011 = 500 kHz
    010 = 250 kHz
    001 = 125 kHz
    000 = 31.25 kHz (INTRC source drives clock directly)
    I don't understand the issue?
    EN82fn
    Never mind
    Sep 2006
    so I guess
    the clocking below 4Mhz cannot be used with HPWM ?
    Cause I need to get down to 50Hz, my choices is left with pulsout command.
    I'll see if I CAN use it on the same pin.
    K
    Sep 2010
    Las Vegas, NV
    I'm curious what do you mean? Bits 0 to 3 set status bit, oscillator stability and mode select. Can't these be set at beginning of code?
    Sorry Dave. I still don't get it. 60 on the table I use comes out to 0111100 in binary. Are we choosing the bits from left to right (MSB first) instead of right to left (LSB first)?
    Oct 2011
    I think this is the problem
    You are reading $60 as decimal when it is a HEX number
    60 = 00111100 in binary
    $60 = 01100000 in binary
    Phil
    Thank you Phil. Makes perfect sense now.
  1. My project is starting
    By cncmachineguy in forum General
    Last Post: - 15th February 2011, 01:56
  2. Starting with PIC18F
    By Gérard in forum mel PIC BASIC Pro
    Last Post: - 7th May 2006, 16:40
  3. Starting PC from PIC
    Last Post: - 25th February 2006, 14:42
  4. Help starting a 876A
    By Naslund in forum mel PIC BASIC Pro
    Last Post: - 20th March 2005, 09:25
  5. Help for someone just starting
    By Ed Cannady in forum mel PIC BASIC Pro
    Last Post: - 30th March 2003, 11:17
