Pulse Narrower
Results 1 to 5 of 5
Thread: Pulse Narrower
    i'm not 100% sure of the purpose of this but, is this input pulse will also be used for something else too??? if not why not just using an RC circuit with a voltage comparator, op-amp, FET, MOSFET or else to do the job? OR an OLD NE555 as monostable??
    Also you can use interrupt to generate your pulse with PAUSEUS or PULSOUT. Depending of what else the PIC is doing, it could work really well.
    It's possible that i don't understand... if so, just tell me.
    matth's Avatar
    matth Guest
    You are right any of those would likely work. Just thought Picbasic might be easier. Any good references on doing something like this with a 555?
    Need to get my old tech school books out.
    Matt
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. pulse simulation
    By nicolasronan in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 18:55
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 11:39
