serin timout not going to correct lable
Results 1 to 2 of 2
    Aug 2009
    Paso Robles California
    Post serin timout not going to correct lable
    below is a serin2 statement that seems to start back at version rather than go to die is there something I'm missing
    VERSION:
    B = 1
    GOSUB FLASH
    PAUSE 500
    B = 1
    GOSUB FLASH
    PAUSE 500
    B = 3
    GOSUB FLASH
    PAUSE 500
    LOW PORTA.5
    GOTO UNIT_TYPE
    Die:
    PAUSE 2000
    B = 5
    GOSUB FLASH
    PAUSE 1000
    B = 5
    GOSUB FLASH
    PAUSE 1000
    LOW PORTA.5
    unit_type:
    FOR Z = 1 TO 16
    SERIN2 PORTA.1,16468,1000, Die,[HEX1 X0(Z)] 'GET BYTE 1 DATA
    SEROUT2 PORTA.0,16468,[HEX1 X0(Z)] 'SEND BACK BYTE 1 ECHO
    NEXT Z
    Apr 2011
    Kent, UK
    Default Re: serin timout not going to correct lable
    Is the data input line (RX) idling low (9600 baud, inverted)? If not then then it will never time out!
  1. "gosub" to lable in included file?
    By amgen in forum mel PIC BASIC Pro
    Last Post: - 5th August 2011, 21:44
  2. Is it a correct way to deal with an interrupt?
    Last Post: - 15th November 2009, 23:44
  3. correct my code for 16f84.....
    By kvrajasekar in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 13:11
  4. Is this the correct PIC?
    Last Post: - 6th May 2008, 17:44
  5. Correct syntax please ?
    Last Post: - 11th June 2006, 10:09
