I have a 128x64 0.94" mono oled with ssd1306, I copied and tried CircuitDomain's modified code since he's using same device but I couldn't see any graphics on screen :\
I'm using 16f877a and made necessary changes on code. I'm able to drive the screen with arduino uno but I want to use it with PIC.
'==========================MCU SETUP============================================
DEFINE OSC 16
DEFINE I2C_HOLD 1
DEFINE CCP1_REG PORTC
DEFINE CCP1_BIT 2
DEFINE CCP2_REG PORTC
DEFINE CCP2_BIT 1
OPTION_REG=0
ADCON0=0
ADCON1=7
CCP1CON=001111
CCP2CON=001111
TRISA=111111
TRISB=000001
TRISC=0
TRISD=0
TRISE=0
PORTA=0
PORTB=0
PORTD=0
'============================I/O SETUP==========================================
' BT var PortB.4
LED var PortB.3
'================================usuart========================================
'==============================BAUD SETUP=======================================
I2CDevice var byte
SCL var PortC.3 ' I2C Clock PortC.3
SDA var PortC.4 ' I2C Data PortC.4
TEXT VAR BYTE[20]
LENGTH VAR BYTE[2]
DC VAR byte' "DATA OR COMMAND", $40=DATA; $0=COMMAND --> changed from bit to byte
LCD_DATA VAR BYTE
COM VAR BYTE'COMMAND
I VAR BYTE
J VAR BYTE
X VAR BYTE' LCD POSITION X(0 TO 127)
Y VAR BYTE'LCD POSITION Y(0 TO 7)
CLEAR
'PAGE = $B0
I2CDevice = $78 ' X/Y/Z = $3C, Display = $78,
PAUSE 20
GOSUB INIT
GOSUB CLEAR_LCD
GOSUB TITLE
MAIN:
COM=$A6:GOSUB SEND_COMMAND '$A6=NORMAL MODE;$A7=INVERSE MODE
'PAUSE 100
COM=$2E:GOSUB SEND_COMMAND
COM=$27:GOSUB SEND_COMMAND
COM=$00:GOSUB SEND_COMMAND
COM=$03:GOSUB SEND_COMMAND
COM=$04:GOSUB SEND_COMMAND
COM=$06:GOSUB SEND_COMMAND
COM=$FF:GOSUB SEND_COMMAND
COM=$2F:GOSUB SEND_COMMAND
'PAUSE 10000
GOTO MAIN
'=========================lcd initialization====================================
INIT:
COM=$AE:GOSUB SEND_COMMAND' DISPALY OFF
COM=$20:GOSUB SEND_COMMAND' HORIZONTAL MODE
COM=$40:GOSUB SEND_COMMAND' DISPLAY START AT 0
COM=$A1:GOSUB SEND_COMMAND' REMAP 0-127 ----> Mirror display
COM=$C8:GOSUB SEND_COMMAND' SCAN DIRECTION
COM=$DA:GOSUB SEND_COMMAND' COM PINS ------> Not Sure what this does
COM=$10:GOSUB SEND_COMMAND' COM PINS ------> Not Sure what this does
COM=$A4:GOSUB SEND_COMMAND' DISPLAY ON
COM=$A7:GOSUB SEND_COMMAND' $A6=NORMAL MODE;$A7=INVERSE MODE
COM=$AF:GOSUB SEND_COMMAND' DISPLAY ON
'==============================clear lcd========================================
CLEAR_LCD:
FOR J=0 TO 7
FOR I=0 TO 127
LCD_DATA=$00:GOSUB SEND_DATA ' was $00
NEXT I
NEXT J
'****************SEND COMMAND************************************************
SEND_COMMAND:
dc=0
'SHIFTOUT SDA,SCL,1,[DC\1]'SEND COMMAND BIT(D/C=0)
'SHIFTOUT SDA,SCL,1,[COM\8]
high LED
I2CWrite SDA,SCL,I2CDevice,DC,[COM]
Low led
dc=$40
'======================Send data===============================================
SEND_DATA:
DC=$40
'SHIFTOUT SDA,SCL,1,[DC\1]'SEND DATA BIT(D/C=1)
'SHIFTOUT SDA,SCL,1,[LCD_DATA\8]
high LED
I2CWrite SDA,SCL,I2CDevice,DC,[LCD_DATA]
Low led
'=============================FILL=============================================
FILL:
FOR J=0 TO 7
FOR I=0 TO 127
LCD_DATA=$FF:GOSUB SEND_DATA
NEXT I
NEXT J
'=========================TITLE=================================================
TITLE:
X=0:Y=0 :GOSUB SET_XY
FOR I=0 TO 127
LOOKUP I,[$00,$40,$60,$50,$7E,$50,$60,$40,$02,$06,$0E,$1E,$3E,$00,$00,$00,_
$00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,$1C,$00,_
$00,$7F,$7F,$61,$61,$61,$61,$61,$61,$3F,$1E,$00,$00,$1E,$3F,$61,_
$61,$61,$61,$61,$61,$38,$18,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
$00,$00,$00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,_
$1C,$00,$00,$1E,$3F,$61,$61,$61,$61,$61,$61,$38,$18,$00,$00,$3F,_
$7F,$60,$18,$06,$06,$18,$60,$7F,$3F,$00,$00,$00,$00,$00,$00,$00,_
$00,$00,$00,$1C,$63,$41,$5D,$41,$5D,$41,$5D,$41,$5D,$41,$7F,$00],LCD_DATA
lcd_data=lcd_data rev 8
GOSUB SEND_DATA
NEXT I
X=0:Y=1 :GOSUB SET_XY
for i=0 to 127
lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
$00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,$F8,$00,_
$00,$FE,$FE,$80,$80,$80,$80,$80,$80,$00,$00,$00,$00,$18,$1C,$86,_
$86,$86,$86,$86,$86,$FC,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
$00,$00,$00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,_
$F8,$00,$00,$18,$1C,$86,$86,$86,$86,$86,$86,$FC,$78,$00,$00,$FE,_
$FE,$00,$00,$00,$00,$00,$00,$FE,$FE,$00,$00,$00,$00,$00,$00,$00,_
$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
GOSUB SEND_DATA
NEXT I
X=0:Y=3:GOSUB SET_XY
for i=0 to 127
lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$7E,$C3,$C3,$C3,$C3,_
$C3,$C3,$71,$30,$00,$00,$7F,$FF,$C3,$C3,$C3,$C3,$C3,$C3,$C3,$C3,_
$00,$00,$7F,$FF,$C1,$C1,$C1,$C1,$C1,$C1,$FF,$7F,$00,$00,$7F,$FF,_
$C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$3F,$7F,$C0,$C0,$C0,$C0,_
$C0,$C0,$70,$30,$00,$00,$FF,$FF,$03,$03,$03,$03,$03,$03,$FF,$FF,_
$00,$00,$C0,$C0,$C0,$C0,$FF,$FF,$C0,$C0,$C0,$C0,$00,$00,$FF,$FF,_
$0C,$0C,$03,$03,$00,$00,$FF,$FF,$00,$00,$3F,$7F,$C0,$C0,$C0,$C1,_
$C1,$C1,$79,$39,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
GOSUB SEND_DATA
NEXT I
X=0:Y=4:GOSUB SET_XY
for i=0 to 127
lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$30,$38,$0C,$0C,$0C,$0C,_
$0C,$0C,$F8,$F0,$00,$00,$F8,$FC,$0C,$0C,$0C,$0C,$0C,$0C,$0C,$0C,_
$00,$00,$FC,$FC,$80,$80,$80,$80,$80,$80,$FC,$FC,$00,$00,$FC,$FC,_
$80,$C0,$60,$30,$18,$0C,$04,$00,$00,$00,$F0,$F8,$0C,$0C,$0C,$0C,_
$0C,$0C,$38,$30,$00,$00,$FC,$FC,$00,$00,$00,$00,$00,$00,$FC,$FC,_
$00,$00,$0C,$0C,$0C,$0C,$FC,$FC,$0C,$0C,$0C,$0C,$00,$00,$FC,$FC,_
$00,$00,$00,$00,$C0,$C0,$FC,$FC,$00,$00,$F0,$F8,$0C,$0C,$0C,$8C,_
$8C,$8C,$F8,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
GOSUB SEND_DATA
NEXT I
X=0:Y=5:GOSUB SET_XY
for i=0 to 127
lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1F,$3F,$30,$30,$30,$30,_
$30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1F,$0F,_
$00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$1F,$0F,$00,$00,$00,$00,_
$00,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1C,$0C,$00,$00,$30,_
$30,$30,$30,$3F,$3F,$30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,_
$30,$30,$30,$1E,$0E,$00,$00,$3F,$3F,$03,$03,$00,$00,$00,$00,$3F,_
$3F,$00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$3F,$1F,$00,$00,$3F,_
$3F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
GOSUB SEND_DATA
NEXT I
X=0:Y=6:GOSUB SET_XY
for i=0 to 127
lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$C0,$C0,$C0,$C0,_
$C0,$C0,$00,$00,$00,$00,$FC,$FE,$03,$03,$03,$03,$03,$03,$FE,$FC,_
$00,$00,$FF,$FF,$E0,$F0,$D8,$CC,$C6,$C3,$81,$00,$00,$00,$00,$00,_
$00,$00,$00,$0C,$8E,$C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$03,_
$03,$03,$03,$FF,$FF,$03,$03,$03,$03,$00,$00,$FC,$FE,$03,$03,$03,_
$63,$63,$63,$7E,$7C,$00,$00,$FF,$FF,$00,$00,$C0,$C0,$30,$30,$FF,_
$FF,$00,$00,$FF,$FF,$60,$60,$60,$60,$60,$60,$FF,$FF,$00,$00,$FF,_
$FF,$03,$03,$03,$03,$03,$03,$03,$03,$00,$00,$00,$00,$00,$00,$00],lcd_data
GOSUB SEND_DATA
NEXT I
'===========================================SET X AND Y=========================
SET_XY:
COM=$21:GOSUB SEND_COMMAND
COM=X:GOSUB SEND_COMMAND
COM=127:GOSUB SEND_COMMAND
COM=$22:GOSUB SEND_COMMAND
COM=Y:GOSUB SEND_COMMAND
