When using Graphic displays to generate characters, It's up to you when generating the character pattern to allow for the space between the characters ie 5x7 format now becomes 6x7 format.
EN82fn
This is NOT only graphic display, this is standard, LCDOUT compatible module, with built-in fonts, which can be switched in graphics mode also. Will try to get the datasheet.
