Understanding the basic about transistor
Results 1 to 2 of 2
    Default Understanding the basic about transistor
    I have a transistor 2N2222A. The max Vbe is 6V - I understood that.
    Can I ask if it is OK to pull the base -20v below emitter? The datasheet does not specify any -ve limit. Can someone help me understand this basic concept?
    ___________________
    WHY things get boring when they work just fine?
    Nov 2007
    West Covina, CA
    Default Re: Understanding the basic about transistor
    The Vbe is 0.6V. The positive voltage on the base with respect to the emitter referring to Base-Emitter saturation and also causing Collector-Emitter saturation.
    Looking at a datasheet, the 6V referred to is the Emitter-Base Breakdown Voltage. This would mean a max of +6V at the emitter with respect to the base putting a Max -6V at the base.
    So a -20V is too much.
    Louie
  1. Transistor Affecting Timings?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 21st April 2012, 04:55
  2. PIC Basic Code Understanding
    By pr2don in forum mel PIC BASIC Pro
    Last Post: - 8th June 2010, 15:33
  3. NPN Transistor
    By rondo2 in forum General
    Last Post: - 10th September 2009, 02:44
  4. Choosing a transistor
    Last Post: - 1st October 2008, 22:16
  5. LED with Transistor
    By mimi_deviL in forum Schematics
    Last Post: - 9th February 2008, 08:03
