How to write pwm using picbasic pro?
Results 1 to 3 of 3
    Haydn303's Avatar
    Haydn303 Guest
    Default How to write pwm using picbasic pro?
    Feb 2012
    PERTH AUSTRALIA
    Default Re: How to write pwm using picbasic pro?
    heres an example that may be of value i found that i found usefull , its for the 18f1825 , it does not use all the pic pasic pro command set but if you just do a search on PWM on forum , you will soon find many examples
    '	PWM_TEST.BAS
    '	WRITTEN BY DAVID PUROLA 04/05/2012
    '	WRITTEN FOR USE W/16F1825 E/P @ 32 Mhz.
    DEFINE OSC 32
    DEFINE NO_CLRWDT 1
    ;----- CONFIG1 Options --------------------------------------------------
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
    ;----- CONFIG2 Options --------------------------------------------------
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    '				Declare Port Variables
    COMOUT		VAR	PORTA.0	'0-OUTPUT COMMUNICATIONS PORT PIN
    COMIN		VAR	PORTA.1	'1-INPUT COMMUNICATIONS PORT PIN
    FEEDBK	    VAR	PORTA.2	'1-ANALOG INPUT FROM POSITION POT
    RST			VAR	PORTA.3	'1-RESET/MCLR
    BATTERY		VAR	PORTA.4	'1-ANALOG INPUT FROM BATTERY VOLTAGE
    RS485TX		VAR	LATA.5	'0-DRIVER ENABLE INPUT TO RS-485
    RUNLED		VAR	LATC.0	'0-RUN LED
    ESTOP		VAR	PORTC.1	'1-ESTOP INPUT FROM BUTTON
    CWLIM	  	VAR	PORTC.2	'1-CW HARD LIMIT SWITCH
    CCWLIM		VAR	PORTC.3	'1-CCW HARD LIMIT SWITCH
    CCW			VAR	LATC.4	'0-PWM CCW OUTPUT
    CW			VAR	LATC.5 '0-PWM CW OUTPUT
    '				Define Constants
    NREADS		CON	16		'A/D READINGS TO AVERAGE
    MAXCHANNELS	CON	2		'NUMBER OF A/D CHANNELS
    OFF_		CON	0		'DIGITAL 0 NUMONIC
    ON_			CON	1       'DIGITAL 1 NUMONIC
    SINK		CON	0		'MOTOR SINK CURRENT NUMONIC
    SOURCE		CON	1		'MOTOR SOURCE CURRENT NUMONIC
    SPAN		CON	2040	'WORKING VALUE SERVO FULL SCALE SPAN
    '		       Declare Variables
    BITSWORD	VAR	WORD BANK0	'BITS FOR STORAGE
    TX_EMPTY    VAR BITSWORD.0	'TRANSMIT BUFFER EMPTY FLAG
    RX_BUFFULL  VAR BITSWORD.1  'RECEIVER BUFFER FULL FLAG
    RX_MESSAGE	VAR BITSWORD.2	'MESSAGE RECEIVED FLAG
    COWS_HOME	VAR BITSWORD.3	'LOOP FLAG
    MSBIT		VAR BITSWORD.4	'SIGN FLAG FOR MATH
    MSGSTAT		VAR BITSWORD.5	'SIGN FLAG FOR CORRECT MESSAGE
    TXPAR		VAR	BITSWORD.6	'PARITY ENABLE FLAG
    PARITYTYPE	VAR BITSWORD.7	'PARITY TYPE (1=ODD/0=EVEN)
    VOLTS	 	VAR	WORD[MAXCHANNELS]	'A/D READINGS (N-CHANNELS)
    AV_VOLTS 	VAR	WORD[MAXCHANNELS]	'A/D READINGS (N-CHANNELS)
    ADREADS 	VAR	WORD[NREADS * MAXCHANNELS]'A/D READINGS (0-65535) (N-CHANNELS * N-READS)
    ADINDEX		VAR	BYTE[MAXCHANNELS]	'RING INDEX POINTER (N-CHANNELS)
    CHANNEL		VAR	BYTE	'A/D CHANNEL VARIABLE
    BITINDEX	VAR	BYTE	'SCRATCH VARIABLE
    SCRATCH	    VAR	WORD	'SCRATCH VARIABLE WORD
    JUNK	    VAR	BYTE	'SCRATCH VARIABLE
    JUNK1	    VAR	BYTE	'SCRATCH VARIABLE
    SCRATCH1	VAR	WORD	'SCRATCH VARIABLE WORD
    DIR			VAR	BYTE	'DIRECTION BIT,BYTE PATERN FOR PWM STEERING LOGIC
    FINAL		VAR	WORD	'FINAL EQUATION OUTPUT
    HALFSPAN	VAR	WORD	'HALF SPAN ERROR LIMITER
    '				SYSTEM INITIALIZATION
    	clear
    	PORTA = %00000000
    	PORTC = %00000000
    	TRISA = %00101110	'INITIALIZE PORT DIRECTIONS
    	TRISC = %00000000	'INITIALIZE PORT DIRECTIONS
        OSCCON = %11110000	'SET SYSTEM CLOCK SWITCH BIT
        INTCON = %00000000 'CLEAR GIE,PEIE,TMR0IE,INTE,RBIE,TMR0IF,INTF,RBIF
       	PIE1 = %00000000    'CLEAR ALL INTERRUPT ENABLE BITS
       	PIR1 = %00000000    'CLEAR ALL INTERRUPT FLAGS
        PIE2 = %00000000    'CLEAR ALL INTERRUPT ENABLE BITS
      	PIR2 = %00000000    'CLEAR ALL INTERRUPT FLAGS
        APFCON0 = %10000100	'ENABLE USART ON PORTA.0:1
    	APFCON1 = %00000000	'ALL DEFAULT
        ANSELA = %00010100	'AN2,AN4 ANALOG,:AN0,AN1 DIGITAL I/O
    	WPUA = %00000000	'WEAK PULLUP'S OFF
        INLVLA = %00111111	'SCHMITT TRIGGER
    	ANSELC = %00000000	'PORTC, DIGITAL I/O
    	WPUC = %00000000	'WEAK PULLUP'S OFF
    	INLVLC = %00111111	'SCHMITT TRIGGER
      	ADCON0 = %00000000  'CHS2:0,GO/DONE,ADOFF
      	ADCON1 = %11100000  'RIGHT JUSTIFIED,FOSC/64,VSS,VDD
    	SRCON0 = %00000000
    	SRCON1 = %00000000
       	CM1CON0 = %00000000	'CLEAR/DISABLE COMPARATOR
       	CM1CON1 = %00000000	'CLEAR/DISABLE COMPARATOR
       	CM2CON0 = %00000000	'CLEAR/DISABLE COMPARATOR
       	CM2CON1 = %00000000	'CLEAR/DISABLE COMPARATOR
      	CMOUT = %00000000	'DISABLE OUTPUT REGISTER
       	DACCON0 = %00000000	'CLEAR/DISABLE D/A
       	DACCON1 = %00000000	'CLEAR/DISABLE D/A
      	FVRCON = %00000000	'DISABLE FIXED VOLTAGE REFERENCE
        OPTION_REG = %10000000 'CLEAR ALL PULL-UPS,INTEDG,T0CS,T0SE,PSA,PS
       	T1CON = %00010101	'PRESCALER 1/2,START TIMER 1
       	T1GCON = %00000000	'NO GATE CONTROL
        T4CON = %00000000	'POSTSCALER 1/1,STOP,PRESCALER 1/1
       	T6CON = %00000000	'POSTSCALER 1/1,STOP,PRESCALER 1/1
       	T2CON = %00000110	'POSTSCALER 1/1,START,PRESCALER 16
    	CCPTMRS = %00000000'SET COMPMPARES 1,2,3 FOR TIMER 2
       	TMR2 = 0			'CLEAR TMR2 MODULE REGISTER
       	PR2 = 255			'SET PERIOD ((((1 / 40,000,000)*4)*16 PRESCALE)*(1+255 PR2)) = 2.44 KHZ
       	CCP1CON = %00001100	'PLACE CCP1 INTO PWM MODE
       	CCPR1L = $00		'CLEAR CCP1 LOWER 8 BITS
       	CCPR1H = $00		'CLEAR CCP1 UPPER 2 BITS
       	CCP2CON = %00000000	'PLACE CCP1 INTO DISABLE MODE
       	CCP4CON = %00000000	'PLACE CCP1 INTO DISABLE MODE
       	TMR4 = 0			'CLEAR TMR2 MODULE REGISTER
       	TMR6 = 0			'CLEAR TMR2 MODULE REGISTER
       	PR4 = $FF			'SET PERIOD (1/1 PRESCALE * 256 PR2 * 1/20,000,000 * 4 = 19.53 Khz.
       	PR6 = $FF			'SET PERIOD (1/1 PRESCALE * 256 PR2 * 1/20,000,000 * 4 = 19.53 Khz.
       	CCPR2L = $00		'CLEAR LOWER 8 BITS
       	CCPR2H = $00		'CLEAR UPPER 2 BITS
       	CCPR3L = $00		'CLEAR LOWER 8 BITS
       	CCPR3H = $00		'CLEAR UPPER 2 BITS
       	CCPR4L = $00		'CLEAR LOWER 8 BITS
       	CCPR4H = $00		'CLEAR UPPER 2 BITS
    	GOTO MAINLOOP
    '				SUBROUTINES
    READAD:	'READ SYSTEM A/D VOLTAGES (AVERAGE 64 READINGS) 16F1825
    	ADCON0 = $01 | ((CHANNEL + 2) << 2)		' Set A/D to Channel X, On
    	PAUSEUS 40
    	VOLTS(CHANNEL) = 0     'CLEAR A/D READINGS
    	SCRATCH = 0
    	WHILE SCRATCH < 64     'SUM 64 READINGS
            ADCON0.1 = 1		' START CONVERSION
    		WHILE ADCON0.1 = 1	'WAIT FOR A/D TO FINISH
    		WEND
            VOLTS(CHANNEL) = VOLTS(CHANNEL) + (((ADRESH & $3) << 8) + ADRESL)	'BUILD SENSOR WORD
    		SCRATCH = SCRATCH + 1
    	WEND
    	VOLTS(CHANNEL) = VOLTS(CHANNEL) >> 5	'TURN INTO 11 BIT RESULT
    	ADINDEX(CHANNEL) = (ADINDEX(CHANNEL) + 1) & (NREADS - 1)	'INCREMENT INDEX POINTER
    	ADREADS((CHANNEL * (NREADS)) + ADINDEX(CHANNEL)) = VOLTS(CHANNEL)	'STORE IN RING BUFFER
    AVERAGE_AD:		'AVERAGE N X 16 BIT VALUES WO/LONG OR 32 BIT MATH
    	SCRATCH = 0 ' Zero to Start
    	SCRATCH1 = 0
    	JUNK = 0
    	WHILE JUNK < NREADS
    		SCRATCH = SCRATCH + ADREADS((CHANNEL * NREADS) + JUNK)
    		If SCRATCH < ADREADS((CHANNEL * NREADS) + JUNK) then
    			SCRATCH1 = SCRATCH1 + 1	' Detect overflow and carry...
    		JUNK = JUNK + 1
    	WEND
    	JUNK = ((NCD NREADS) - 1)
    	SCRATCH = SCRATCH >> JUNK
    	JUNK = JUNK - 1
    	BITINDEX = 15
    	WHILE JUNK < 255
    		SCRATCH.0(BITINDEX) = SCRATCH1.0(JUNK)
    		JUNK = JUNK - 1
    		BITINDEX = BITINDEX - 1
    	WEND
    	AV_VOLTS(CHANNEL) = SCRATCH
    OUTPWM:		'OUTPUT NEW PWN VALUE
    	LATC.4 = SINK	'PRESET PORT PIN LOW
    	LATC.5 = SINK	'PRESET PORT PIN LOW
    	PSTR1CON = %00010000 | DIR	'1=CW (PWM P1A/STATIC STATE P1B, 2=CCW (PWM P1B/STATIC STATE P1A
    	CCPR1L = FINAL >> 2	'UPDATE PWM1 UPPER 8 BITS
    	CCP1CON = $0C | ((FINAL & $3) << 4)	'UPDATE PWM1 LOWER 2 BITS
    MAINLOOP:'				PROGRAM LOOP
    	HALFSPAN = SPAN / 2
    	REPEAT
    		CHANNEL = 0		'FEEDBACK POT
    		GOSUB READAD	'READ SYSTEM A/D VOLTAGES (AVERAGE 64 READINGS)
    		GOSUB AVERAGE_AD	'AVERAGE N X 16 BIT VALUES WO/LONG OR 32 BIT MATH
    		FINAL = VOLTS(0) - HALFSPAN
    		DIR = FINAL.15
    		DIR = 1 << DIR
    		IF FINAL.15 = 1 THEN FINAL = ABS(FINAL)
    		FINAL = FINAL MIN HALFSPAN
    		GOSUB OUTPWM		'OUTPUT NEW PWN VALUE
    	UNTIL COWS_HOME
    	END				'SHOULD NEVER GET HERE.........
    	STOP
    Dec 2009
    Warrenton Mo
    You didn't mention which type of PWM you wanted, HWPM for continous PWM, or regular. Here is a quickie program that flashes a LED from full bright to dimly lit. It's good for an indication of some kind.
    Install a LED on portb.0
    T var byte' set-up the loop variable
    For t=1 to 20' amount of bright/dim  flashes
    portb.0=1:pause 90:portb.0=0' full bright ON time then turn OFF---experiment with the ON time.
    PWM portb.0,20,80' the 20 is LED brightness, the 80 is it's ON time--Again experiment with the numbers, try changing the 20 to 50.
    TRISb=0' Once PWM is used on a pin, then that pin only wants PWM to be used. The TRISb resets the pin back to normal output.
    next t' end of loop
    If you had inputs on portb, like portb.1, and portb.2, then use TRISb=%00000110
    While PWM is operating, nothing else is being done. Same way with SOUND. When using a servo, when PWM stops, the servo no longer gets data causing it to lose it's position if it was under a load. To correct this you would need to use the HWPM.
    Hope this helped.
    Electroken
    Last edited by Demon; - 6th May 2013 at 01:04. Reason: Used CODE tags so :p does not turn into emoticon
    The more I think about it the worse off I am
  1. conversion from picbasic to picbasic pro
    By winjohan in forum mel PIC BASIC Pro
    Last Post: - 1st November 2011, 19:00
  2. PICBasic Pro vs Proton PICBasic
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 17:11
  3. How would i write this in pic basic pro (Servo controller)
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 09:21
  4. PicBasic Pro - Is it possible
    By tracking in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2005, 22:14
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
