Wireless modules - help with code not working
Results 1 to 32 of 32
    Dec 2011
    IO93ok
    Default Re: Wireless modules - help with code not working
    OK as you can guess I'm at the pc doing the programming right now.
    I'm sending SEROUT2 PortA.3,T9600,["BOB",redstop] where variable redstop is allocated redstop = 1
    on the other unit ---
    I'm trying to receive SERIN2 PortA.2,84,[WAIT("BOB"),signal] to put the received value into variable 'signal' .
    If signal =1 then gosub
    Whatever combination I try, straight or DEC it doesn't respond.
    Am i doing something stupid?
    Rob
    1. Serout2 and T9600 are not compatible. Use 84 instead.
    2. Are you sure of the correct ports and connections? Try it directly from PIC to PIC.
    Dec 2011
    IO93ok
    Yesssss. That was it !
    Read the manual so many times I was confused over what worked with what. Changed to 84 and it works.
    Thank you Loannis
    Glad you got it.
    It is a good feeling when it works, isn't it?
  1. Wireless modules and simple setup, what is required?
    By tasmod in forum mel PIC BASIC Pro
    Last Post: - 11th April 2013, 17:57
  2. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 05:20
  3. Wireless modules FCC approved
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 02:23
  4. Software RS232 and wireless modules
    Last Post: - 17th August 2008, 05:27
  5. Wireless comms with Linx LR modules
    By telemark in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2006, 01:58
