Wireless modules - help with code not working
Results 1 to 32 of 32
Threaded View
  1. #16
    Dec 2011
    IO93ok
    Default Re: Wireless modules - help with code not working
    At last. Working.
    Redesigned pcb's but not reconfigured. Just turned pic sideways for ease of removal and added pads for each pin to facilitate cross connection, although not finally needed.
    After making up the boards I wrote the most simple TX/RX routines and connected the 3 pins needed with temporary jumpers. They immediately talked to each other. Replacing the jumpers with the modules and they talked !!!!
    There was one change in code that needed to be added but later removal and they still talked although not quite 100%. That was the extra first characters "SSSSSSSSBOB" before the required string to match the serin string of "BOB"
    Send code -------------
    Include "modedefs.bas"
    DEFINE OSC 10
    TRISA = %00000000
    CMCON=7
    pause 2000
    TEST:
        serout PortA.3, T9600,["SSSSSSSBOB"]
        PAUSE 500
        GOTO TEST
    Receive code -----------------------------
    DEFINE OSC 10
    TRISA = %11111101
    CMCON=7
    relay var PortA.1
    low relay
    pause 2000
    TEST:
        low relay
        serin PortA.2,T9600,["BOB"]
        high relay
        PAUSE 1000
        GOTO TEST
    Now I need to expand the code to do just what I want and to then add a decent antenna to get the range.
    I'm considering a 'Moxon' Rectangle which gives 3dbd gain with excellent f/b ratio fitted directly to modules via short solid wire. It can be made up using UK twin earth cable wire. About 1.5mm copper. It's very small indeed at 123x46mm
    Rob
  1. Wireless modules and simple setup, what is required?
    By tasmod in forum mel PIC BASIC Pro
    Last Post: - 11th April 2013, 17:57
  2. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 05:20
  3. Wireless modules FCC approved
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 02:23
  4. Software RS232 and wireless modules
    Last Post: - 17th August 2008, 05:27
  5. Wireless comms with Linx LR modules
    By telemark in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2006, 01:58
