At last. Working.
Redesigned pcb's but not reconfigured. Just turned pic sideways for ease of removal and added pads for each pin to facilitate cross connection, although not finally needed.
After making up the boards I wrote the most simple TX/RX routines and connected the 3 pins needed with temporary jumpers. They immediately talked to each other. Replacing the jumpers with the modules and they talked !!!!
There was one change in code that needed to be added but later removal and they still talked although not quite 100%. That was the extra first characters "SSSSSSSSBOB" before the required string to match the serin string of "BOB"
Send code -------------
Include "modedefs.bas"
DEFINE OSC 10
TRISA = %00000000
CMCON=7
pause 2000
TEST:
serout PortA.3, T9600,["SSSSSSSBOB"]
PAUSE 500
GOTO TEST
Receive code -----------------------------
DEFINE OSC 10
TRISA = %11111101
CMCON=7
relay var PortA.1
low relay
pause 2000
TEST:
low relay
serin PortA.2,T9600,["BOB"]
high relay
PAUSE 1000
GOTO TEST
Now I need to expand the code to do just what I want and to then add a decent antenna to get the range.
I'm considering a 'Moxon' Rectangle which gives 3dbd gain with excellent f/b ratio fitted directly to modules via short solid wire. It can be made up using UK twin earth cable wire. About 1.5mm copper. It's very small indeed at 123x46mm
Rob
