BUG With MPLAB 8.89 ...
Results 1 to 9 of 9
    Default BUG With MPLAB 8.89 ...
    Hi, The team
    a new message arrived with Mplab 8.89
    Executing: "C:\PBP3\PBPX.EXE" -ampasmwin -k# -p12F1840 "Voltmètre12B.bas"
    PICBASIC PRO(TM) Compiler 3.0.6.4, (c) 1998, 2012 microEngineering Labs, Inc.
    All Rights Reserved.
    Message[303] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\VOLTMèTRE12B.ASM 21 : Program word too large. Truncated to core size. (EF9C)
    Message[303] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\VOLTMèTRE12B.ASM 22 : Program word too large. Truncated to core size. (DFFF)
    Message[303] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\VOLTMèTRE12B.ASM 723 : Program word too large. Truncated to core size. (EF9C)
    Message[303] C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\VOLTMèTRE12B.ASM 723 : Program word too large. Truncated to core size. (DFFF)
    Loaded C:\Program Files\Microchip\MPLAB IDE\Projets\Voltmètre12B.COF.
    BUILD SUCCEEDED: Sun Jan 20 11:33:44 2013
    asm line 21/22
    	__CONFIG	_CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _BOREN_ON & _IESO_OFF
    	__CONFIG	_CONFIG2, _PLLEN_ON & _BORV_LO & _LVP_OFF
    line 723
    This deals with the #CONFIG and END directives.
    Everything was fine with 8.88 Version.
    the .bas program :
    'Voltmètre12.bas
    ' R/C Expanded scale Voltmeter W/ Calibration @ 5v000
    ' Pic 12F1840
    ' 12 Multiplexed Leds
    ' 2 Display modes :
    ' - Jumper ON is Actual voltage BAR Display
    ' - Jumper OFF is Minimun reached Voltage in BAR Mode, plus Actual Voltage in DOT Mode
    ' ( intended to show Voltage swing under load )
    ' 985 Lines
    ' Defines
    DEFINE OSC 32							' not to disturb multiplexing !!!
    DEFINE BUTTON_PAUSE 255
    ' Config
    '#DEFINE Debugg
    OPTION_REG	= %00000001
    WPUA		= %00001000
    OSCCON 		= %11110000					' !!! SCS 1:0 = 00 pour PLL ON !!!
    INTCON 		= 0
    PIE1 		= 0
    T1CON 		= 0
    T1GCON		= 0
    CM1CON0		= 7
    ADCON0		= %00000001
    ADCON1		= %11100011
    FVRCON		= %11010011
    LATA 		= 0
    TRISA		= 255
    ' Aliases
    Modeselect 	VAR PORTA.3
    ' Variables
    Nvalue	VAR WORD
    Ivalue	VAR WORD
    Calval	VAR WORD
    Nominal VAR WORD
    Mvalue	VAR BYTE
    Dvalue 	VAR BYTE
    Value 	VAR BYTE
    I		VAR BYTE
    J		VAR BYTE
    mode	VAR BIT
    modeI	VAR BIT
    CLEAR
    Mvalue 		= 12
    Dvalue 		= 12
    Nominal 	= 8388
    VDD_Res		CON 10
    FVrefmv 	CON 4096
    VRef_AD5	CON EXT
    @Vref_AD5 = (_FVrefmv *100000) / (500000000/ (1 << _VDD_Res))
    FirstCalib:										' !!! 5v000 Supply for calib.!!!
    READ 0,WORD Calval
    IF Calval = $FF THEN Calib						' Calibration ever done ?
    PAUSE 2000										' Settling time
    Jumperon:
    BUTTON Modeselect,0,255,0,I,1,Calib				' Jumper ON : redo calib.
    GOTO test										' Jumper OFF : measure
    Calib:
    TRISA 	= %11111001									' Red Led ON
    LATA 	= %00000100
    PAUSE 1000											' Time to show LED
    ADCON1 = %10110000									' ADC temp. setting
    													' for Calibration
    WHILE !FVRCON.6 : WEND
    ADCIN 31,Calval										' Nominal 838.86 @ 5v000
    Calval = Calval * 10
    WRITE 0, WORD Calval
    ADCON1 = %11100011									' ADC Norm. resetting
    LATA 	= 0
    TRISA 	= %11001111
    LATA	= %00010000									' Green Led ON
    PAUSE 1000											' Time to show Led !
    LATA = 0											' Display OFF
    test:
    Calval = Nominal									' just for the test !!!
    FOR Value = 1 to 12
    	Mode = 0 : ModeI = 0
    	GOSUB Display
    	PAUSE 200
    NEXT Value
    LATA	=	0
    Dvalue = 0
    'Take jumper OFF While test or after PWR OFF to get Alternate mode @ first run
    Displaymode:
    BUTTON Modeselect,0,255,0,I,0,First				' Display actual Voltage
    ModeI = 1										' IF Jumper OFF then Alternate mode
    First:											'
    ADCON0.1 = 1									'Launch First Conversion
    Wait0:
    FOR I = 1 to 16
    	IF ADCON0.1 = 0 THEN
    		Nvalue = ADRESH*256 + ADRESL			' read ADC result if ready
    		GOTO Wait0								' 50µs per conv.
    	ADCON0.1	= 1								' relaunch conversion
    	Ivalue = ( Nvalue +(Ivalue*9)) /10			' First Value for Ivalue
    												' = True value for Mvalue !
    NEXT I
    PAUSE 1000
    WHILE 1
    Wait1:
    		GOTO Wait1
    	Ivalue = (Nvalue + (Ivalue*9))/10			' Rolling average
    	Nvalue = Nvalue * Calval					' Works
    	Ivalue = DIV32 Nominal
    	GOSUB Convert
    	IF Dvalue < Mvalue THEN	Mvalue = Dvalue		' Memorize Minimum
    ' Prepare value to be displayed
    	IF ModeI = 1 THEN
    		FOR I = 0 to Dvalue						' Bar Display Actual value
    			Value = I
    			GOSUB Display
    		NEXT I
    		FOR I = 0 to Mvalue						' Bar Display Min Value
    			Value = I
    			GOSUB Display
    		NEXT I
    			Value = Dvalue						' Add Actual Value dot
    			GOSUB Display
    WEND
    ' SUBROUTINES
    Display:
    LATA = 0										'Prevent Ghosting
    LOOKUP Value,[%11111111,%11111001,%11111001,%11101101,%11101101,%11011101,%11011101,_
    			  %11101011,%11101011,%11011011,%11011011,%11001111,%11001111], TRISA
    LATA.1	= !!(value == 2)|| (value == 4) || (value == 6)
    LATA.2	= !!(value == 1)|| (value == 8) || (value ==10)
    LATA.4	= !!(value == 3)|| (value == 7) || (value ==12)
    LATA.5	= !!(value == 5)|| (value == 9) || (value ==11)
    PAUSE 1
    Convert:										'Convert ADC Counts to LED#
    LOOKDOWN2 Ivalue, < [513,526,538,551,563,576,588,601,613,626,638,651,663,1024], Dvalue
    IF Dvalue > 12 THEN Dvalue = 12
    ''Test purpose values set
    'LOOKDOWN2 Ivalue, < [551,563,576,588,601,613,626,638,651,663,676,688,700,1024], Dvalue
    'IF Dvalue > 12 THEN Dvalue = 12
    This is a nice multiplexed 12 Leds Volmeter ...
    Default Re: BUG With MPLAB 8.89 ...
    This issue affects all languages. It is not specific to PicBasic Pro.
    It only affects the Enhanced core devices (12F1xxx and 16F1xxx).
    Programs are compiled correctly, but non-critical messages are reported.
    Those messages can be supressed with ...
    #HEADER
      errorlevel -303  ; suppress Program word too large
    #ENDHEADER
    Hopefully Microchip will fix it.
    If not, PBP will need to suppress it by default.
    Thank you Darrel ...
    as we ( mere mortals ) do not have possibility to verify compilation is correct ...
    Default Update
    This seems to be a permenant problem with MPLAB now.
    So with PBP 3.0.7.x and later, all [303] messages will be suppressed on the Enhanced core devices.
    If you are getting the "Program word too large. Truncated to core size." messages ... update your version of PBP3.
    Or, Even if you're not getting those messages ... update your version of PBP3.
    If you already have PBP3, the updates are free. So keep it up to date.
    http://pbp3.com/download.html
    Default Re: Update
    After updating to 3.0.7.4 I get
    ERROR: Unable to execute MPASMWIN.
    My MPLAB is 8.85, does it matter?
    Default Re: Update
    Hi, Ioannis
    as the " bug " was linked to the lasts revs of MPLAB ... seems obvious you have to update MPLAB ...
    Everything fine here with MPLAB 8.90 and MCSPX ...
  1. A new MPLAB IDE
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 6th May 2011, 15:31
  2. Mplab x ide
    By fowardbias in forum Off Topic
    Last Post: - 3rd February 2011, 08:32
  3. MPLAB 8.20 and PBP 2.50B
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 12th February 2009, 16:50
  4. Using MPLAB SIM
    Last Post: - 7th July 2006, 04:20
  5. Mplab 7.22
    By Patrick in forum Documentation
    Last Post: - 1st June 2006, 06:32
