Error [113]
Results 1 to 7 of 7
Thread: Error [113]
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default Error [113]
    I cannot understand the reason for an Error [113] message.
    I am using a PIC18F2685 with PBPL.
    DataTP CON EXT ; Tables P
    DataTC CON EXT ; Tables C
    DataTB CON EXT ; Tables B
    DataTS VAR LONG BANK0
    DataTP ;
    #include "KPPV3.ASM"
    EndTP
    DataTC ;
    #include "KPCV3.ASM"
    EndTC
    DataTB ;
    #include "KPBV3.ASM"
    EndTB
    DataTS = DataTC
    movlw LOW DataTS ; Computing DataTS+AdTS
    addwf _AdTS,W ; and storing to Ads(AdsU:AdsH:AdsL)
    movwf _ADSL
    movlw HIGH DataTS
    addwfc _AdTS+1,W
    movwf _ADSH
    movlw UPPER DataTS
    addwfc _ZERO,W
    movwf _ADSU
    I use three external tables.
    I want to select one table and make some operations with it
    I think that the declarations are correct but three Error [113] message are generated, one per line of the asm section where DataTS is used. These errors are related to DataTS which is seen as not being declared.
    If I replace DataTS by DataTC (for example) in the asm section, no errors occur.
    What's wrong ?
    Thank you for your help
    MikeBZH
    Default Re: Error [113]
    ...assembler code
    Look up proper syntax in manual.
    Edit: EndTP, is that a new command in PBP3?
    May 2009
    I found the solution.
    Writing :
    movlw LOW DataTS
    is a non-sense since DataTS is a variable, not a constant
    and movlw stands for "move litteral to w"
    other mov instructions are certainly more appropriate. I need to search.
    Demon, all this syntax comes from Darrel examples. It works !
    MikeBZH
    I don't doubt it works, but are you compiling in PVP or ASM?
    May 2009
    Hi Demon
    I assume you mean PBP, not PVP.
    The code is written in PBP with some sections in ASM.
    You're right. The block :
    DataTP ;
    EndTP
    DataTC ;
    EndTC
    DataTB ;
    EndTB
    is inside an ASM / ENDASM section
    MikeBZH
    PBP, Darn small keypad on cell phone.
    May 2009
    To complete this topic and for anybody interested by the solution :
    DataTS is first splitted into three bytes :
    DataTSL = DataTS.BYTE0
    DataTSH = DataTS.BYTE1
    DataTSU = DataTS.BYTE2
    then the program is the same as before but movlw are replaced by movf
    movf _DataTSL,W
    addwf _AdTS,W
    movwf _ADSL
    movf _DataTSH,W
    addwfc _AdTS+1,W
    movwf _ADSH
    movf _DataTSU,W
    addwfc _ZERO,W
    movwf _ADSU
    No more error. It works.
    MikeBZH
  1. PBP, 16F1827, FSR, and Error 113
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 13th January 2014, 10:04
  2. Replies: 1
    Last Post: - 30th March 2012, 05:13
  3. error 113 _FCMEN_OFF_1H
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 7th November 2008, 18:12
  4. Error code [112]/[113]
    By Dj tempo in forum General
    Last Post: - 17th June 2007, 17:15
  5. Error 113
    By b1arrk5 in forum mel PIC BASIC Pro
    Last Post: - 4th November 2006, 22:36
