Interesting result on a 16F688 with ADC and LCD
Results 1 to 19 of 19
Threaded View
  1. #16
    Jan 2012
    Grid EN19MV
    Default Re: Interesting result on a 16F688 with ADC and LCD
    Quote Originally Posted by wdmagic View Post
    OK I now have something on LCD but its jibberish. I moved chip and lcd to breadboard for time being, PORTC 0-3 is now starting bits, RS is C.4 and E is C.5, nothing else is hooked up except LCD. I will need to turn on ADC for PORTA 0 & 1 after LCD starts working.
    I had trouble without the following two defines (after the ones you already have):
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    Then try this:
    PAUSE 500 ' Wait 0.5sec for LCD to initialize (May need to be one second, depends on your LCD)
    DO
        LCDOUT $FE, 1, "This is a Test"
        Pause 1000
        LCDOUT $FE, 1 'clear the screen
        Pause 250 'wait 1/4 second
    Loop
    No reason the above shouldn't work. Good luck
    -Stephen Hawking
  1. Converting 10bit ADC result to 8 bit
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 5th March 2012, 20:38
  2. Timer0 Reload based on ADC result
    By Cyborg in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2011, 07:11
  3. Replies: 2
    Last Post: - 22nd January 2011, 01:58
  4. 16f688 Adc
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2008, 10:34
  5. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 14:21
