Critique my code, please.
Results 1 to 10 of 10
    Bombay, India
    Default Re: Critique my code, please.
    This seems redundant to me
        if PIP = 0 then increment
        if PIP = 1 then display
    increment:
    It could be
    increment:
    Another possible improvement would be to consider using an interrupt to capture the change in state of PIP. Without that, you could miss / misread the timing since the code could be updating the display and doing a pause thereby losing time before you poll the PIP pin.
    Just a quick note
    CNT = CNT + 1
    IF CNT > 65535 then ' This adds a overload catch so it doesnt run away.
    CNT = 0
    goto no_data2
    The above doesn't really work because CNT is declared as a WORD and can not contain values larger than 65535. The IF statement will never evaluate true so the program will never jump to no_data2. Once CNT is incremented "beyond" 65535 it will automatically wrap around to 0.
    Sep 2009
    Correct way to do that is:
    CNT = CNT + 1
    IF CNT =0 then ' This adds a overload catch so it doesnt run away.
        CNT = 0
        goto no_data2
  1. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  2. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
