Whats going on? serial comm
Results 1 to 10 of 10
    darkman's Avatar
    darkman Guest
    this my working serial com project : ( I'm test it )
    transmitter :
    @ device XT_osc
    INCLUDE "modedefs.bas"
    baslangicdatasi var byte
    TRISB=%01000000
    PORTB=0
    baslangicdatasi=65
    gonder:
    PAUSE 1000
    SEROUT PORTB.7,N2400,["protocol",baslangicdatasi] ' SEND BEFORE "protocol" AFTER SEND baslangicdatasi
    son:
    receiver :
    TRISA=%00000000
    TRISB=%00000011
    B0 var byte
    B1 var byte
    B3 var byte
    B0=0
    PORTA=0
    B3=2
    LOW PORTB.3
    LOW PORTA.2
    HIGH PORTA.0
    start:
    B0=0
    ' IF PORTB.0=0 THEN bekle
    ' GOTO start
    bekle:
    SERIN PORTB.1, N2400, ["protocol"],B0 ' wait "protocol" after write receive baslangicdatasi and insert in B0
    IF B0=65 then kontrol
    GOTO bekle
    kontrol:
    IF B3=2 then ac
    IF B3=1 then kapat
    GOTO kontrol
    Feb 2005
    Holmfirth England
    Angry
    Well thanks for the replies, but still no luck. This should be the easiest bit of the project. Isnt it always the way.
    I have included the code. Display is the transmitter, and fback3 is the receiver. The programs control a welder, display is supposed to tell the feedback chip the desired welding current. I can see the serial input to the pic on the scope but still no output mirrored on the test pin. I have also tested the pins as digital in and out, so i know there is no damage to the chips. I have also written code just to test the comms part with but no difference
    By the way in the display file is a routine to drive a 4 digit 7 seg led display, with blanking of leading zeros. Quite proud of that little routine.
    Thanks again for the help. Hope we can sort it out soon, the boss is back on tuesday :-( lol...
    Bob
    Dec 2003
    Wichita KS
    Hello Bob,
    Instead of wading through the code, can you write *just* the code to send the data?
    When you do so, make sure the sending pin is a I/O pin.
    Make sure you assign it with the TRIS register as a Output
    Make sure you You turn off all ADC's and Comparators.
    If you cannot scope the output on this pin of any data (like the decimal number 1), you are wasting your time with all the other stuff.
    When you get a scoped decimal one, then work on the reciever side.
    When the above is finished, insert it in your code where it belongs.
    MisterE made some EXTREMELY good points... Do not ignore them!
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Feb 2005
    Holmfirth England
    I have scoped the output of the transmitter, no problem with that. To test the circuit I have a PIC16F877A transmitting:
    pause 500 'make sure receiver has time to boot
    let value = 1
    loop:
    serout portb.7, 1, [value]
    goto loop
    and a PIC 16F870 receiver:
    loop:
    serin portb.7, 1, [value] 'get input
    high led
    serout portb.0, 1, [value] 'send to pin to compare waves
    low led
    goto loop
    The led never flashes so its just sat waiting for input which it never sees, though the scope sees a nice clean signal on the input pin.
    I have noted all the points Mr E mentioned. I have tried it on lots of pic types, and various pins, I have included "modedefs.bas", I have a 10k resistor from TX pin to gnd, no comparators to worry about.
    I am going to try disabling the A/D before receiving data, but cant see this making a difference, since I'm using port B
    regards
    Bob...
    darkman's Avatar
    darkman Guest
    loop:
    high led
    'add here PAUSE
    low led
    'add here PAUSE
    goto loop
    and try this software for rs 232 commination capture with pc :
    http://www.rs232pro.com
    Dec 2003
    Wichita KS
    Hello Bob,
    Bob>>loop:
    high led
    low led
    goto loop
    Ok, One thing I see, is that it will only take a very SMALL amount of time to send the data to the output, Thus your LED may be flashing, but too fast.
    Can you scope the POrtb.0? and see the data being transmitted? Do not rely on just 1 LED flashing. (which seems you are doing here). It will flash way too fast, and probably look as if it is not flashing at all.
    Since you have scoped the transmitter, and have verified it, then the reciever should be almost the same...Try scoping the PORTB.0, and making sure you have data coming out. If not, it is in your receiver... Then I would suggest slowing down your baud rate to 300.
    Dwayne
    Bob>>I am going to try disabling the A/D before receiving data, but cant see this making a difference, since I'm using port B <<
    Will not make any difference if they are not present on POrtb. PortA ususally has all the AD and comparators...
    Make sure your TRISB has the proper pins as I/O... according to your example
    your input is PORTB.7 and output is PORTB.0
    Thus I would (for safety sake)
    Portb=%10000000
    This assigns POrtb.7 as a input, and all others as outputs.
    Dwayne
    Ability to Fly:
    Feb 2005
    Holmfirth England
    Smile
    First of all thanks to everyone who replied to my posts. I have now cured the problem
    serout serpin, 0, ["A",#VALUE,"AA"]
    and
    serin serpin, 0, ["A"],#VALUE
    worked just fine.
    Kind regards
    Bob Edge...
  1. Serial comm between two PICs
    By ALFRED in forum Serial
    Last Post: - 13th March 2014, 23:22
  2. Idea of master/slave serial comm.
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 6th December 2007, 08:36
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 4th April 2004, 23:58
