Keypads HELP! hehe, Need advice and possible code.
Results 1 to 14 of 14
Threaded View
  1. #8
    Dec 2012
    Tennessee
    Default Re: Keypads HELP! hehe, Need advice and possible code.
    EDIT: I got it working, it was the TRISB line, I didnt update it for the inputs past 0. So I added TRISB = %11111111 and now its reading the data, its funny though i must have some wires in wrong place because only one row reads corrects numbers all the others are way off, will have to check pinouts of keypad. but its working now
    BEFORE EDIT:
    Ok it was a bit confusing to make sure the INT was firing so I moved the code down to the INT, it places a 0 on LCD when a key is pressed so the interupt is working, but its not reading data on portB
    heres a code update
    include "LCD_D.bas"
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    TRISD = 0                               ' PORTD is Display
    TRISB = 1                               ' PORTB is Input
    asm
            INT_Handler   INT0_INT,  _KEYPRESS,   PBP,  yes
    @   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts
    X VAR BYTE : X = 0
    LCDOUT $FE, 2
    Pause 1000
    PAUSE 500
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    KEYPRESS:
    X = PORTB
    X = X >> 4
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT DEC X
    @ INT_RETURN
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
  1. Membrane Keypads
    By jonathan in forum Adverts
    Last Post: - 15th April 2009, 21:18
  2. Low key count membrane keypads
    By AndrewC in forum General
    Last Post: - 7th April 2009, 20:12
  3. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 19:30
  4. Custom membrane keypads UK
    By Calco in forum Off Topic
    Last Post: - 14th May 2004, 09:02
