Keypads HELP! hehe, Need advice and possible code.
Results 1 to 14 of 14
    Dec 2012
    Tennessee
    Default Keypads HELP! hehe, Need advice and possible code.
    I have 5 4x4 matrix Keypads (Grayhills), and I have 5 74C922N IC's (Keypad Interfaces)
    Now I am trying to use them but they want to use a few capacitors and other IC's in conjuction with the 922 Chip, What I would like is to only have the 922 chip, keypad, and PIC. If this is possible. I have not found good schematics for this, and am unsure what schematic would be best. I was hoping to use the Data Available pin to the INT (RB0) and tie the 4bit to (? PortC 0-3) I could use any pin as the data received. I can use the keypad.bas and tie the keypad strait to the PIC, but I would rather use these chips.
    So what should I use a direct Keypad-PIC connection and software code keystrokes? or Use the 922 Chips with Supporting Chip & Capactors? or Other options someone here may provide.
    My layout of code in my head right now appears like this.
    on INT(RB0) set Variable X = PortC
    send data received to 922 chip
    continute program, program now uses variable X
    PS, im only trying to use 1 keypad, I just noted that I have 5
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Default Re: Keypads HELP! hehe, Need advice and possible code.
    hey Wd, What are you talking about having to use more ic's than the 74C922? All you have to do is put a capacitor with the part to operate the oscillator and wala.... you have a keyboard decoder.... I used these IC's about 30 years ago and acording to the data sheet thay haven't changed. Just tie the tristate output control line low and connect the data available linr to the interrupt line.
    EN82fn
    Dec 2012
    Tennessee
    all the schematics in the data sheet use other chips to help the 922, depending on the configuration you want it uses a 7474, or 7404, or a nand gate. none of the schematics show only the chip. if youve got one please post it to me, I havent found one on the web yet.
    Chris
    Dec 2012
    Tennessee
    Dave I tried that, it gave me really erratic results, numbers were all over the place even above 16. , so i disconnected the 4 data lines to the pic, and tested the lines output
    on the 922 Chip output, with 4 LEDS, pressing any key on pad repeatedly should output the same leds every time, however they blink like christmas lights.
    on the PIC (when INT fired) it outputs 0, 16, 06 randomly each time INT fires.
    tied the datalines back and now PIC does nothing till they are removed???
    Here is the code I am using, although this doesnt solve the issue with the 922 chip outputting random bits
    include "LCD_D.bas"
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    TRISD = 0                               ' PORTD is Display
    TRISB = 1                               ' PORTB is Input
            INT_Handler   INT0_INT,  _KEYPRESS,   PBP,  yes
    @   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts
    X VAR BYTE : X = 0
    LCDOUT $FE, 2
    Pause 1000
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT DEC X
    PAUSE 500
    GOTO Main
    '---[INT - interrupt handler]---------------------------------------------------
    KEYPRESS:
    X = PORTB <<4  '922 Data lines 0,1,2,3 hooked to 4,5,6,7 of PORTB
    @ INT_RETURN
    Chris
    Dec 2012
    Tennessee
    OK the Data Bits from the 922 Chip are working ok now, wrong capacitor was in circuit, i thought it was a .1 and it was a 10. so the 922 chip sends a data available while any key pressed and the 4 data lines go high in binary.
    however the pic is not displaying anything but 0 on the LCD? ive even tried removing the <<4 just to get something out. nothing works. anyone see a problem?
    Chris
    Apr 2013
    I think you have a mistake here
    I belive it has to be like this ;
            INT_Handler   INT_INT,  _KEYPRESS,   PBP,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    actually both are same but you may wanna try
    PS: also "X = PORTB <<4" statement is wrong, change it to "X = PORTB >> 4"
    Dec 2012
    Tennessee
    I tried both , it still only displays a 0
    Chris
    Dec 2012
    Tennessee
    EDIT: I got it working, it was the TRISB line, I didnt update it for the inputs past 0. So I added TRISB = %11111111 and now its reading the data, its funny though i must have some wires in wrong place because only one row reads corrects numbers all the others are way off, will have to check pinouts of keypad. but its working now
    BEFORE EDIT:
    Ok it was a bit confusing to make sure the INT was firing so I moved the code down to the INT, it places a 0 on LCD when a key is pressed so the interupt is working, but its not reading data on portB
    heres a code update
    include "LCD_D.bas"
    asm
    X VAR BYTE : X = 0
    LCDOUT $FE, 2
    Pause 1000
    PAUSE 500
    GOTO Main
    KEYPRESS:
    X = PORTB
    X = X >> 4
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT DEC X
    @ INT_RETURN
    Chris
    Well Chris, I'm glad you got it going. Did you learn anything? Do you still need those other support IC's? Thats all it takes is a little persiverance.
    EN82fn
    Dec 2012
    Tennessee
    nope you dont these those other IC's, I notice when you start adding outside chips wether it be a temp sensor or a 40 pin digital IC, it has a adverse affect on the project if you have an error, because you cant always test the externals as well as the PIC, and settings can be crucial. a missing CAP, a wrong value CAP, and a TRIS statement was the major problems here. I couldnt find the problem because there was internal and external problems at the same time.
    NOTE: I did have to add a capacitor to the KeyBounce pin on the 922.
    Chris
    Just a little note:
    This code fiirst moves cursor to top of screen, then moves cursors to beginning of line 1. That's the same thing.
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT DEC X
    You can simplify that with:
    LCDOUT $FE, 1, DEC X
    It will clear the screen, move cursor to first line and display value.
    Also, what happens if you try this?
    X = PortB >> 4
    Dec 2012
    Tennessee
    yes thats how i had X set up at first, I just had the>> going the wrong way, I can now put it back like that .
    on the screen clearing, ive got to stop using clear except when initializing because of LCD flicker, but i should be able to do
    LCDOUT $FE, $80, DEC X , " " 'add spaces to cover excess leftover characters
    That way all the other data on screen stays wile updateing line 1
    Chris
    That makes sense.
  1. Membrane Keypads
    By jonathan in forum Adverts
    Last Post: - 15th April 2009, 22:18
  2. Low key count membrane keypads
    By AndrewC in forum General
    Last Post: - 7th April 2009, 21:12
  3. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 20:30
  4. Custom membrane keypads UK
    By Calco in forum Off Topic
    Last Post: - 14th May 2004, 10:02
