Ok now, something very funny and absurd has happened Before explaining everything, I want to thank again everybody for their help.
I started to test codes and tried to find where was the exact problem. First of all, yes Robert you were right TMR0 instantly starting to run after "@ INT_ENABLE TMR0_INT" I replaced it's location first and then while looking for problem, I figured out that program is running "STANDUP" and "ENCOUNTER" programs only once, then I stopped calling "ENCOUNTER" and I saw that "STANDUP" is working very fine. Then I added another subroutine to program for testing, just toggling a pin and called it instead of "ENCOUNTER" there was no problem, everything was perfect.
So, what was the problem with "ENCOUNTER" I comment all lines of "ENCOUNTER" and started to comment out line by line to see where is the problem exactly. While I commenting out lines, I compiled and tried the program on every line of "ENCOUNTER".
Well now is the funny part, at the end commenting out of lines, while I was thinking "damn I tried all lines and got no error, now its back to old code and wont work as it is" it worked without any problem.. I didnt change any letter of "ENCOUNTER" just commented them in and out thats all, but it worked... Now it counts pulses and stops in right time..
I'm glad problem is solved, but does anyone have any idea about this stuation?
Here is working codes I compiled last.
DEFINE OSC 16
INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
        INT_Handler   TMR0_INT,  _kesme,   PBP,  yes
     ; enable Timer 0 interrupts
 ADCON1=7
'Defining Port usages and clearing ports for start
 TRISA=%00000000
 TRISB=%00000000
 TRISC=%11110000
 TRISD=%00000011
 PORTA=0
 PORTB=0
 PORTC=0
 PORTD=0
'DEFINE ENCODER INPUTS
 SYMBOL EN1=PORTC.7
 SYMBOL EN2=PORTC.6
 SYMBOL EN3=PORTC.5
 SYMBOL EN4=PORTC.4
 SYMBOL EN5=PORTD.1
 SYMBOL EN6=PORTD.0
'DEFINE MOTOR CONTROL OUTPUTS
 SYMBOL M1A=PORTB.7
 SYMBOL M1B=PORTB.6
 SYMBOL M2A=PORTB.5
 SYMBOL M2B=PORTB.4
 SYMBOL M3A=PORTB.3
 SYMBOL M3B=PORTB.2
 SYMBOL M4A=PORTD.7
 SYMBOL M4B=PORTD.6
 SYMBOL M5A=PORTD.5
 SYMBOL M5B=PORTD.4
 SYMBOL M6A=PORTD.3
 SYMBOL M6B=PORTD.2
 'DEFINE VARIABLES
 wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
 EN1PRE var BIT
 EN1NOW var BIT
 EN2PRE var BIT
 EN2NOW var BIT
 EN3PRE var BIT
 EN3NOW var BIT
 EN4PRE var BIT
 EN4NOW var BIT
 EN5PRE var BIT
 EN5NOW var BIT
 EN6PRE var BIT
 EN6NOW var BIT
 M1STEPSIZE VAR BYTE
 M2STEPSIZE VAR BYTE
 M3STEPSIZE VAR BYTE
 M4STEPSIZE VAR BYTE
 M5STEPSIZE VAR BYTE
 M6STEPSIZE VAR BYTE
 M1STATE VAR BYTE
 M2STATE VAR BYTE
 M3STATE VAR BYTE
 M4STATE VAR BYTE
 M5STATE VAR BYTE
 M6STATE VAR BYTE
 STANDC VAR BYTE
 M1C var BIT
 M2C var BIT
 M3C var BIT
 M4C var BIT
 M5C var BIT
 M6C var BIT
 walk_mode var byte
 duty_check var BIT
 duty_ctrl var BIT
 duty1 var byte
 duty0 var byte
 M1POWER var BIT
 M2POWER var BIT
 M3POWER var BIT
 M4POWER var BIT
 M5POWER var BIT
 M6POWER var BIT
 STANDUP_COUNT VAR BYTE
 CLEAR          'Clear all variables
'Defining starting values of some variables
 M1STEPSIZE=50
 M2STEPSIZE=50
 M3STEPSIZE=50
 M4STEPSIZE=50
 M5STEPSIZE=50
 M6STEPSIZE=50
 EN1PRE=EN1
 EN2PRE=EN2
 EN3PRE=EN3
 EN4PRE=EN4
 EN5PRE=EN5
 EN6PRE=EN6
 M1POWER=0
 M2POWER=0
 M3POWER=0
 M4POWER=0
 M5POWER=0
 M6POWER=0
 STANDUP_COUNT=50
 pause 2000
 walk_mode=0 'walk_mode defines which movement mode RHEX will use
OPTION_REG=%10000100
 TMR0=255   'Start Timer so interrupts and movement will start
'RHEX IS STANDING UP
'Check every motor encoder value and stop releated motor if it reached to
'defined position
'MXC is used for motor running control, if a motor is reached to desired
'position and stopped, do not check and lose time on it
 STANDUP:
 gosub ENCOUNTER
      IF M1C=0 THEN
         IF M1STATE>=STANDUP_COUNT THEN
                M1POWER=1
                M1C=1
                STANDC=STANDC+1
     IF M2C=0 THEN
         IF M2STATE>=STANDUP_COUNT THEN
                M2POWER=1
                M2C=1
                STANDC=STANDC+1
     IF M3C=0 THEN
         IF M3STATE>=STANDUP_COUNT THEN
                M3POWER=1
                M3C=1
                STANDC=STANDC+1
     IF M4C=0 THEN
         IF M4STATE>=STANDUP_COUNT THEN
                M4POWER=1
                M4C=1
                STANDC=STANDC+1
     IF M5C=0 THEN
         IF M5STATE>=STANDUP_COUNT THEN
                M5POWER=1
                M5C=1
                STANDC=STANDC+1
     IF M6C=0 THEN
         IF M6STATE>=STANDUP_COUNT THEN
                M6POWER=1
                M6C=1
                STANDC=STANDC+1
     IF STANDC>=6 THEN
@    INT_DISABLE  TMR0_INT
        M1STATE=0
        M2STATE=0
        M3STATE=0
        M4STATE=0
        M5STATE=0
        M6STATE=0
        STANDC=0
        PAUSE 2000
        GOTO STANDUP
'COUNTING PULSES FROM ENCODER OUTPUTS
'Read values of encoders and if they are different from previous value
'then it means, a transition is occured, so a pulse is given
'increase the releated encoder count
'Note: This will cause 2 counts for every pulse, not 1 count for 1 pulse.
 ENCOUNTER:
     EN1NOW=EN1
     EN2NOW=EN2
     EN3NOW=EN3
     EN4NOW=EN4
     EN5NOW=EN5
     EN6NOW=EN6
     IF EN1NOW!=EN1PRE THEN
        M1STATE=M1STATE+1
     EN1PRE=EN1NOW
     IF EN2NOW!=EN2PRE THEN
        M2STATE=M2STATE+1
     EN2PRE=EN2NOW
     IF EN3NOW!=EN3PRE THEN
        M3STATE=M3STATE+1
     EN3PRE=EN3NOW
     IF EN4NOW!=EN4PRE THEN
        M4STATE=M4STATE+1
     EN4PRE=EN4NOW
     IF EN5NOW!=EN5PRE THEN
        M5STATE=M5STATE+1
     EN5PRE=EN5NOW
     IF EN6NOW!=EN6PRE THEN
        M6STATE=M6STATE+1
     EN6PRE=EN6NOW
'TMR0 INTERRUPT ROUTINE
'All motor movements are provided by this interrupt routine
'A PWM signal is created by using TMR0 timer and applied to
'motors, all PWM signals will be created by TMR0 for all movement types
kesme:
    if walk_mode=0 then
       duty1=90
       duty0=(256-duty1)
        if duty_check=0 then
             duty_ctrl=1
              M1A=1
              M1B=M1POWER
              M2A=M2POWER
              M2B=1
              M3A=1
              M3B=M3POWER
              M4A=M4POWER
              M4B=1
              M5A=1
              M5B=M5POWER
              M6A=M6POWER
              M6B=1
             TMR0=duty1
        if duty_check=1 then
             duty_ctrl=0
              M1A=0
              M1B=0
              M2A=0
              M2B=0
              M3A=0
              M3B=0
              M4A=0
              M4B=0
              M5A=0
              M5B=0
              M6A=0
              M6B=0
              TMR0=duty0
        if duty_ctrl=1 then
        duty_check=1
        duty_check=0
@ INT_RETURN
