Program works!, however dont understand some DT-INT stuff.
Results 1 to 10 of 10
    Dec 2012
    Tennessee
    Default Re: Program works!, however dont understand some DT-INT stuff.
    Sorry changed the top 2 lines to
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    'I also changed INT_INT to INT0_INT
    throws error
    Error 101 INT_ENABLE Priority state not found
    does this no matter the INT0 change
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Hi Chris,
    First, regarding the timer. You are correct on all accounts. Changing from $31 to $30 does strip of setting the least significant bit which results in the timer being left in its off state. You can set the bit indivudually if you want.
    Second, in your latest code snippet you're declaring an interrupt for TMR1 (TMR1_INT) but you're then trying to enable the interrupt for TMR0 - which at that point doesn't have an interrupt service routine assigned to it.
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    		INT_Handler   TMR1_INT,  _ToggleLED2,   PBP,  yes
    @    INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    @    INT_ENABLE  TMR0_INT     ; enable Timer 0 interrupts   <- Here you're enabling TMR0_INT which isn't properly declared.
  1. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  2. Some pins dont work
    By The Master in forum General
    Last Post: - 2nd December 2007, 21:00
  3. I don't understand this program
    Last Post: - 15th June 2006, 23:03
  4. Need Help To Understand This Program
    By Danish in forum mel PIC BASIC
    Last Post: - 9th August 2005, 22:07
