OK Got a problem, took and went back to basics and just want a timer to flash a LED and a button on RB0 (int)
heres my code, the INTCON and OPTION are remarked out because I copied them in from other notes on web, not sure if they were correct and they threw sytax errors
Code:INCLUDE "DT_INTS-14.bas" ' Base Interrupt System INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler INT_INT, _ToggleLED1, PBP, yes INT_Handler TMR1_INT, _ToggleLED2, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE INT_INT ; enable external (INT) interrupts @ INT_ENABLE TMR0_INT ; enable Timer 0 interrupts 'INTCON = %10011000 <--not sure if this was needed or incorrect (it was not in the blinky or the hello word program) 'OPTION_REG = %01000000 <-- same as above, shows up as syntax error (Both lines copied from other peoples code) 'without these 2 lines I get INTCON, INTF not found T1CON = $11 ; 01=.5s, 11=1s Main: PAUSE 500 GOTO Main '---[INT - interrupt handler]--------------------------------------------------- ToggleLED1: Toggle PORTB.1 @ INT_RETURN '---[TMR0 - interrupt handler]-------------------------------(Animation)------ ToggleLED2: Toggle PORTB.2 @ INT_RETURN
