Can someone help me identify why this simple program won't compile?
Results 1 to 7 of 7
    Default Re: Can someone help me identify why this simple program won't compile?
    What PIC, PBP version, ASM version?
    Can you post all your entire code?
    Have you tried just blinking an LED on port e.2?
    Mar 2013
    Florida
    The PIC that this would be loaded to, if it ever got tested would be 16F877a
    I have Microcode Studio 5.0.0.3 Compiler 3.0.6.3 and whatever assembler came down when I downloaded this all together.
    If the ASM version is still important, you will have to direct me to where I find that bit of information.
    This code sample is complete, but if it does not look complete, that may be the problem. I took the code from the book to test the LCD.
    Thanks, Joe
    Make sure you select the correct target device in the drop down list in MicroCode Studio before compiling.
    If you're compiling for a chip which doesn't have a PortE (for example) then the compiler doesn't know what to do with the command LOW PortE.2 so it throws a Syntax Error.
    I've tried your code here, compiling ot for 16F877A, and it compiles without any errors.
  1. Compile problems with simple RF remote control example
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 18th July 2012, 06:22
  2. Can anyone compile a C program for me?
    By circuitpro in forum Off Topic
    Last Post: - 25th February 2012, 10:22
  3. ICD Compile Program in MicroCode Studio Plus
    By Mike2545 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2010, 17:29
  4. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
