HSERIN advice
Results 1 to 11 of 11
Thread: HSERIN advice
    Feb 2005
    GREECE
    THAT IS MY CODE IHAVE ALREADY WRITTEN BUT IT IS NOT WORKING PROPERTLY.
    ANY IDEA?
    SerData = 0
    HSERIN [SerData]
    IF SerData <> 0 THEN
    hserout ["You typed:", SerData,10,13]
    Goto Main
    PAUSE 1000
    Goto OUT
    Pause 1000
    OUT:
    I2CWRITE SDA0, SCL0, DISPLAYCONTROLBYTE1, DIGIT0BOTHPLANESADDRESS, ["SerData[1]"]
    I2CWRITE SDA0, SCL0, DISPLAYCONTROLBYTE1, DIGIT1BOTHPLANESADDRESS, ["SerData[2]"]
    I2CWRITE SDA0, SCL0, DISPLAYCONTROLBYTE1, DIGIT2BOTHPLANESADDRESS, ["SerData[3]"]
    I2CWRITE SDA0, SCL0, DISPLAYCONTROLBYTE1, DIGIT3BOTHPLANESADDRESS, ["SerData[4]"]
    Feb 2005
    GREECE
    That is a part of my program.Where is the wrong?The only thing I can see in hyperterminal is nikos.I can not put the 8 ASCII CHARACTERS.Hyperterminal does not allow me!!!
    Any idea?
    INCLUDE "MODEDEFS.BAS"
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    CMCON = 7
    SerData VAR BYTE [8]
    Hserout [10,13,"nikos",10,13]
    Pause 5000
    HSerin 5000,Main,[ STR SerData\8]
    PAUSE 500
    HSEROUT ["You typed:", STR SerData\8,13,10]
    PAUSE 500
    Goto OUT
    OUT:
    I2CWRITE SDA0, SCL0, DISPLAYCONTROLBYTE2, DIGIT0BOTHPLANESADDRESS, ["SerData[5]"]
    Hyperterminal is the best piece of ^^%#^ that i've never ever work with. Did you try with another program like MicroCodeStudio , RealTerm or else???
    Also, don't forget that once you type something... your program will go to LaLaLand since you didn't tell to return to [main]. But probably it's an copy paste error too.
    Can you also remove the PAUSE 5000 at the begining???
    Feb 2005
    GREECE
    Post
    I would like to say the truth,I am working with Tera Term pro,which has no problem.
    My program looks good or not?
    Please advice.
    i tried by removing all the delay... no problems here. just smething must be 13,10 intead of 10,13
    Feb 2005
    GREECE
    I tried that using the serial communicator.That is what I see WITHOUT sending any character:
    You typed: You typed: α
    You typed: α
    You typed: Φ
    You typed: Φ
    You typed: Φ
    You typed: Φ
    It seems like sending by itself bytes.Where is the problem?
    loop: IF RCIF = 1 THEN
    Hserin [Serdata[1]] ' Get a char from serial port
    goto starty
    HSEROUT ["You typed: ", SerData[1],10,13]
    GOSUB OUT
    Goto loop
    starty: Hserout ["Nothing",10,13]
    Goto loop
    out:
    Here's a simple routine I use for testing. It will buffer up to 80 bytes, and
    print it after receiving the end of message ~ character.
    DEFINE  LOADER_USED 1
    DEFINE  OSC 20
    DEFINE  HSER_CLROERR 1  ' Automatically clear over-run errors
    DEFINE  HSER_RCSTA 90h	' Enable USART receive
    DEFINE  HSER_TXSTA 24h	' TXSTA=%00100100. TX enable, BRGH=1 for high-speed
    'DEFINE  HSER_TXSTA 20h	' TXSTA=%00100000. TX enable, BRGH=0 for low-speed
    GP      VAR BYTE        ' GP variable
    BytesIn var byte[80]    ' Up to 80 bytes
    ByteCnt var byte        ' Indicates number of bytes in buffer
    EOM     CON "~"         ' EOM = "End Of Message" marker
    OERR    VAR RCSTA.1     ' Alias USART over-run bit
    CREN    VAR RCSTA.4     ' Alias USART continuous receive enable bit
    RCIF    VAR PIR1.5      ' Alias USART received character interrupt flag bit
    INTCON  = 0			    ' Disable interrupts
    ByteCnt = 0             ' Zero counter
    ADCON1 = 7              ' A/D off, all digital
        IF RCIF THEN            ' If RCIF=1 there's a new character in RCREG
         BytesIn[ByteCnt]=RCREG ' Yes. Then store it in array
         IF BytesIn[ByteCnt]=EOM THEN OutMsg
         ByteCnt=ByteCnt+1      ' Increment array index pointer
        GOTO Main
    OutMsg:
        HSEROUT [13,10,dec ByteCnt," bytes received",13,10]
        HSEROUT [STR BytesIn\ByteCnt,13,10]
        FOR GP=0 TO ByteCnt   ' Clear array bytes 0 to ByteCnt
         BytesIn[GP]=0        '
        NEXT                  '
        ByteCnt=0             ' Reset index pointer back to first element
        WHILE RCIF            ' Keep reading until RCIF is clear to flush buffer
         GP=RCREG             ' after EOM is received
        WEND
        GOTO Main
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. timeout of Hserin, goto, gosub or both?
    By flipper_md in forum mel PIC BASIC Pro
    Last Post: - 28th October 2009, 19:43
  2. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  3. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  4. Hserin not working...
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 13:25
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
