This is totally untested but could serve as a starting point for a polled receive buffer. Short of this you need to use interrupts to receive the data in the background but I suspect that with your timing sensetive loop even that might cause to much problem.
RC1IF VAR  PIR1.5   'Alias to Interrupt request bit for USART1, double check against datasheet.
RxData VAR BYTE[5]
Value VAR WORD
ByteCount VAR BYTE
TestVar1 VAR WORD
TestVar2 VAR WORD
ByteCount = 0   ' Reset buffer pointer.
' Main loop has to run faster than the bytes can arrive.
If RC1IF THEN              ' Is there a byte in the receive buffer?
   HSERIN[RxData[ByteCount]]    ' Get it and put in the buffer array, RCIF will be cleared by the hardware.
   IF ByteCount = 4 THEN           ' Do we have 5 bytes yet?
      GOSUB ProcessFrame              'If so go process them...
      ByteCount = ByteCount + 1    ' If not, get ready for the next.
Goto Main
ProcessFrame:
   ByteCount = 0   ' Get ready for next frame.
   ' Now convert the next 4 bytes from ASCII to a numeric value.
   ' Could probably use ArrayRead here instead.
   Value = (RXData[1] - 48) * 1000
   Value = Value + ((RxData[2] - 48) * 100)
   Value = Value + ((RxData[3] - 48) * 10)
   Value = Value + (RxData[4] - 48)
   If RxData[0] = "A" THEN
     TestVar1 = Value
   If RxData[0] = "B" THEN
     TestVar2 = Value
