Timer Function? Not sure what I need here.
Results 1 to 5 of 5
    Dec 2012
    Tennessee
    Default Timer Function? Not sure what I need here.
    I need to call a sub on a schedule, say every 30 minutes. The sub reads 8 ADC's into a VAR Array and sets PORTB based on those numbers.
    I dont need it so accurate that I would need a RTC, but I would like to get in the neiborhood of 30 minutes. and I need it to do this like an interupt where it will fire even in a pause mode.
    Here is what I need to call every 30 minutes (and optional on button would be nice but PORTB INT's are being used)
    ReadVolts:
    For X = 0 to 7
    PORTE = X   'Activates Binary Relays
    PAUSE 100     ' Allow Relay contacts to settle before ADC Conversion
    ADCIN 0, VOLTS[X]               ' Read Channel 0 data
    VOLTS[X] = VOLTS[X] / 13        ' 64k = ~5000 mv  (temporary math)
    if VOLTS[X] > 4000 then
    PORTB.0[X] = 1
    PORTB.0[X] = 0
    PauseUS 100                     ' Pause for ADC Refresh
    NEXT X
    PORTB uses Bipolar LEDs for status indicators. I am going to assume I need to use one of the internal timers, but I have never used them. So if anyones got any ideas or code samples....
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Default Re: Timer Function? Not sure what I need here.
    Have you looked at
    http://www.picbasic.co.uk/forum/showthread.php?t=3251
    Edit: checking if 30 minutes has passed is one possibility:
    Dec 2012
    Tennessee
    yea thats a thought, I didnt think of useing darrels INT's, I havent messed with them yet. I was waiting till I had a few days to play with them and other bits of his code.
    right now I need to use a internal timer INT? I think. Using a 18F4550 chip. so something like timer1 set for every 30 minutes using DT's INT's
    I might need a second timer to run a second sub to flash a led, not sure if this can be done so that they dont conflict. will post some code in a bit as example.
    Do you think thats the best way though to do the 30 minute timer INT using DT_INTS? trying to KISS! "keep it simple stupid" want program small but stable.
    Chris
    You probably won't be able to set up any hardware timer to interrupt at a rate as low once every 30 minutes - if you don't run the PIC REALLY slow that is.
    What you usually do is set it up to interrupt at something like 10Hz or whatever and then keep track of the number of interrupts in order to get a total of 30 minutes (18000 interrupts in this case). That way you can use the same timer and interrupt for the LED flashing and any other timing tasks you might need.
    Darrels DT-Ints are a great way to this.
    Personally, I'd check if 30 minutes elapsed; as KISS as you get.
    Check DT's thread and link to his site for details.
  1. ARCSIN function
    By mjphillips1981 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:19
  2. Hash function
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 7th September 2007, 10:09
  3. Need help with write function
    Last Post: - 12th July 2006, 04:12
  4. COUNT Function
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 28th June 2006, 06:26
  5. log10 function
    By dampf in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 17:54
