On-Chip eeprom problem DATA READ command
Results 1 to 2 of 2
    Apr 2012
    Ptolemaida
    Angry On-Chip eeprom problem DATA READ command
    AM i going nuts ?! srly until yesterday EVEYTHING was good. Im doing a project with some Led dot matrix and i need to store some fonts. I used on-chip eeprom of my 18F26K22. I dont know if i did something wrong i can't recall but i can't write on the eeprom. I used an other 18F26K22 but still same results. Is there any specific number of times that you can write on Eeprom ?? I remember that you can write many many many times until it gets destroyed...
    SO i tried to write 2 bytes on the eeprom and recall them to 1 Hserout to check where the problem is. BUT still !!! all data i got back was $FF ....
    Doesn't $FF mean eeprom is empty ??
    Here are the registers i set.
    '----REGISTERS---------
    TRISA= %00000000
    TRISB= %00000010
    TRISC= %11000000
    'CMCON= 7 'Comparator module OFF
    INTCON.6= 1 'Set Pheripheral Interrupts
    PIE1.5= 1
    ANSELA=0
    ANSELB=0
    ANSELC=0
    clear
    pause 250
    Here is an image from the simply data-read command i tried with an Hserout indicator.
    If you see anything i miss please let me know !! Im heading out to get some fresh air, can't stand this any more !!
    Apr 2012
    Ptolemaida
    Default Re: On-Chip eeprom problem DATA READ command
    I found it !! it was stupid as ALL misstakes with programming PICs :P :P
    My mistake was this
Size:  10.6 KB and afterName:  Working!!!.jpg
Size:  11.0 KB !!!!
  1. read command of EEprom errors
    Last Post: - 16th April 2012, 12:25
  2. How to read stored data from MCU EEPROM into PC?
    Last Post: - 3rd October 2009, 15:26
  3. PIC18 (452) DATA or EEPROM Command
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 16th August 2007, 16:14
  4. Bootloader + EEPROM / DATA Command Question
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 20:01
  5. 18F252 internal EEPROM / DATA, READ
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 1st June 2004, 14:01
