Just a thought !
When using the ACIN command for A/D conversion
How is this turned off before going to sleep ?
Does pbp automatically take care of it
Isaac
Just a thought !
Isaac
yes Think automatically take care of it i dot have no problems using the A/D.
Hi Jetpr,
Thanks for the code you sent, I got it working good and I also managed to write some code using push buttons so I can set a reference to warn when the battery voltage drops to whatever level I want, that way if it works the way I envision it to work then I can use different battery combinations and just set my reference (dependent of pretty much any battery source) to sound an alarm when the batteries voltage drop to a certain level. I managed to find some 1% 10K resistors at my local electronics store and with your code it shows 6.5 volts with 4 fresh AA alkaline batteries, the actual voltage of the batteries is 6.43 volts using an old Micronta DMM to check them but I think that's ok. I connected a 5k pot to the ADC as well and it Max's at 10.0 volts and down to 0.0 volts, I'm hoping that's ok? This is my first time working on a project that uses batteries so it should be interesting. I have the reference push buttons code set up so I can set it to tenths of a volt, just like the code you sent me. I can't wait to get some good voltage regulators to try it out.
Thanks man..........
Issac wrote:
Just a thought !
Hi Issac,
What I did is to use ADCON1 = 7 statement to turn off the ADC then I set the ADC pin as an output and then set it low with PORTA.0 = 0, that seemed to work good. I noticed that I saved on my milliamp draw by setting the ADC pin low after shutting it off. Before I tried setting it low, the consumption didn't go below (if I remember correctly) about .068mA and would fluctuate (bouncing up and down) up to about.086mA. Then after I set it low it dropped to about .006mA minimum and fluctuates up to about .044 -.060mA and about every 4 or 5 seconds it jumps up to .104mA but just for a ever so brief time, so it did make a big difference forcing it low. To turn the ADC back on I just used Trisa.0 = 1 then ADCON1 = $0E or ADCON1 = 2 but that'll depend on which chip your using..........good thing for me they keep Archives! LOL
Maybe someone could tell me if that's the proper way of doing it, I would imagine there is more than one way of doing it for sure. I just ordered some MIC2954, 250mA Low Dropout Voltage Regulators. The web site I ordered them from just listed them as MIC2954, I don't know if their MIC2954-02BZ or MIC2954-0B3Z or even what the difference is, I think maybe I read something about .5% and 1% but their suppose to be pretty good for battery operated micro's. I also read you have to play around with the capacitor values to get the minimum amp draw. It looks like their pin compatible with a 7805 in a TO-92 case. It says in the data sheet that (if I'm reading it properly) that it uses a low quiescent current (120mA typical) and that it will operate down to 2 volts and produce a 5 volts output? I'm not very good at reading data sheets, anyone here used these before with any success?
Thanks jessey
you probably read correct but paste with error...120uA quiescent... wich is more suitableOriginally Posted by jessey
i've never use those but they looks good.
