Battery voltage monitoring for use on 16F1825
Results 1 to 20 of 20
    Dec 2010
    Default Re: Battery voltage monitoring for use on 16F1825
    Removing R12 will have no impact on PGD. The resistor divider might be another matter, but the values are reasonably large, so I doubt it. Worst case you can add a programming jumper, but it won't be necessary. Double check the spec if you are in doubt.
    USA - Arizona
    Values look good, and calculations match your expectations. I like R12 (bot not 10K, something like 330 or 1,000) only because it provides a bit of isolation from the gate. But Charlie is right, it probably makes little difference. Best way is to go ahead and try it, and then optimize as needed.
    As far as the N-ch FET, not sure this would work for this application as the turn-voltage for a "bad" condition would be the same as the ADC voltage for the "good" condition.
  1. Voltage Monitoring
    Last Post: - 11th July 2011, 23:51
  2. ADCIN car battery monitoring
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 08:04
  3. pwm with voltage monitoring
    By jetpr in forum General
    Last Post: - 29th January 2008, 08:49
  4. 12v car battery monitoring
    By oldcarguy85 in forum Schematics
    Last Post: - 10th December 2007, 00:26
  5. Using the A/D for Monitoring a Solor Cell and Battery
    By chuck.sieveking in forum mel PIC BASIC Pro
    Last Post: - 13th July 2004, 19:27
