Battery voltage monitoring for use on 16F1825
Results 1 to 20 of 20
Threaded View
  1. #10
    Dec 2010
    Default Re: Battery voltage monitoring for use on 16F1825
    You can reduce the complexity with an N-channel FET by changing the order from +3.3V / FET / LED / R / GND to 3.3V / LED / R / FET / GND. Now R12 can be replaced with a piece of wire. Set the voltage divider to be about 3V when the battery is at maximum, and choose a FET that is full on with VGS ~1V.
    By the way, if you are using a high powered LED, they typically have a forward volt drop closer to 3V, so your 100 ohm resistor might be too large.
  1. Voltage Monitoring
    Last Post: - 12th July 2011, 00:51
  2. ADCIN car battery monitoring
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 09:04
  3. pwm with voltage monitoring
    By jetpr in forum General
    Last Post: - 29th January 2008, 09:49
  4. 12v car battery monitoring
    By oldcarguy85 in forum Schematics
    Last Post: - 10th December 2007, 01:26
  5. Using the A/D for Monitoring a Solor Cell and Battery
    By chuck.sieveking in forum mel PIC BASIC Pro
    Last Post: - 13th July 2004, 20:27
