Hi Hendric , yes its gong to be a bit tricky , as the pin is digital output normally ACTIVE LOW , then need to go setup ACD on the pin , sample positive voltage , then switch bak, but the goal is to have some battery monitor on the main input voltage to the regulator , this will make the power LED flash at a rapid rate when battery is low , ( normally power led would flash 1 time in 2 sec or so)
The mosfet chosen has to allow gate to source voltage larger than say 5v???
see attached proposed diagram
Cheers
Sheldon
Name:  proposed adc ver.BMP
