Noob needs some help please...
Results 1 to 12 of 12
    May 2008
    Default Re: Noob needs some help please...
    Some one shoot me! I figured it out 10 minutes after posting. It is branching... I was relying on the loop for the delay for the LCD to display the info. once I put in the "Main Loop" and "LCD Info" bit for debugging they would immediately overwrite the LCD info from the branch, and I would not see it of course.
    For some reason posting a question here causes me to find the answer almost immediately afterwards. Thanks for the "Magic" this site casts on me.
    Apr 2012
    Ptolemaida
    Same happens with me !! Try to make some flowchart on paper with a pencil or on any programm it helps to think and see clear ur code. Also try some beer or a coffe for a change :P xaxaxa
    Regards Kostas.
    May 2008
    Thanks for the tips!! I'll give the flow chart a try. I don't drink coffee and it's a little too early for beer
    This looks like trouble in your code. You gosub to "check_button:" and then goto "button_loop:" if a button is pressed. This creates a case where the gosub never returns, which can cause problems. Beer may help.
    check_button:
            if btn_up = 0 OR btn_dwn = 0 OR btn_back = 0 _  ' If any button is pressed
                OR btn_nxt = 0 OR btn_entr = 0 then         ' Go to button loop
                High lcd_lite                               ' Turn on the LCD Backlight
                goto button_loop
    May 2008
    That bit has been reworked as follows...
    check_button:
            if btn_up = 0 OR btn_dwn = 0 OR btn_back = 0 _  ' If any button is pressed...
                OR btn_nxt = 0 OR btn_entr = 0 _            ' and the LCD Backlight is on...
                and lcd_lite = 1 then                       ' Then Go to button loop
                goto button_loop
                OR btn_nxt = 0 OR btn_entr = 0 _            ' and the LCD backlight is not on...
                and lcd_lite = 0 then                       ' Then turn on the backlight...
                high lcd_lite                               ' ...and pause 2 seconds
                pause 2000               ' Holding the button longer than 2 sec. gets you to...
            endif                        ' the button loop VIA the mainloop & check_button and...
            return                       ' IF statement above.
    But the GOTO / GOSUB seems ok... At least is seems to be working.
    button_loop:
    if btn_up = 1 and btn_dwn = 1 and btn_back = 1 _  ' If no buttons are pressed go to mainloop...
        and btn_nxt = 1 and btn_entr = 1 then
     goto mainloop
        endif                                         ' Otherwise continue...
    button_set_loop:
    if btn_up = 0 then up                   ' If the up button is pressed go to the Up loop
    if btn_dwn = 0 then down                ' If the down button is pressed go to the Down loop
    if btn_back = 0 then back               ' If the back button is pressed go to the Back loop
    if btn_nxt = 0 then forward             ' If the next button is pressed go to the Next loop
    if btn_entr = 0 then                    ' If the enter button is pressed go to the Enter loop
            goto enter
            goto button_loop                ' If no buttons are pressed run the button loop again...
    endif                                   '   ... which takes you to the main loop.
    up:
    while btn_up = 0                ' While the Up button is pressed do this loop...
    pause 30                        ' pause for 30 milliseconds
    alrm_set = alrm_set + 1         ' increase alarm set point by one degree F
    lcdout $FE, 1, "Alarm Set ", _  ' Display the alarm set point as it's changed
    dec (alrm_set),$DF, "F"
    pause 300
    wend                            ' Repeat, increasing it 1 degree F every ~1/3...
    lite_timer = 0                     '   ... second until the switch is released
    goto button_loop
    down:
    while btn_dwn = 0
    pau... (and it continues)
    The check_button loop returns to the main loop, the button_loop series all end with a GOTO mainloop so it finds its way back. In the code above what I wanted to accomplish was that any button press would turn on the LCD backlight but not increment the variable in button_loop in doing so. The above code work pretty well though I may back off the 2 second pause.
    I'm aware that there is much room for improvement in both the code and the hardware... I'm learning as I go. I'm working with a deadline of April 17th so I don't have the time to pretty it up. The hardware is functional with some software work-arounds... Rev B will be awesome!
    The IF statement about all the buttons being "1" (not pressed) is likely not necessary since it was a button press that got me there in the first place. Cleaning up that stuff will come later, right now it doesn't break anything and I'm not tight on space yet.
    Thanks for looking it over I'm grateful for any tips.
    PS I know... interrupts and timers... in Rev B
    GOTO out of a subroutine is never a good idea.
    Set a flag before GOSUB, change the flag within the subroutine, then check the flag once you've returned and GOTO at that point.
    Edit: it may work this time, but it's a habit you don't want to get into.
    May 2008
    I don't follow... can you give a quick example?
  1. PICKit2 vs. JDM (Noob question)
    By loamobn in forum General
    Last Post: - 19th September 2010, 19:19
  2. NOOB in need of help
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 00:01
  3. Help a noob out?
    By yasiryassin in forum mel PIC BASIC
    Last Post: - 15th January 2008, 07:37
  4. (noob)hello world?
    By m4gill4 in forum mel PIC BASIC
    Last Post: - 30th November 2007, 01:23
  5. Uber noob needs clarity!
    By bill12780 in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2007, 22:40
