Strange problem with button command and loop
Results 1 to 6 of 6
    Default Strange problem with button command and loop
    Hello.
    I'm continiuing to evaluate PBP pro, so I built a simple circuit with 16F682A, two leds and a button (tied to Vdd via 10k resistor and when pushed, connects the pin to gnd) leds are tied to rb0 and rb1 via 1k resistors.
    The code is below:
    LED    VAR  PORTB.0
    LED2    VAR PORTB.1
    brep var byte
    mainloop:
    BUTTON PORTB.3,0,255,10,brep,1,secondled
       High LED
       Pause 250
         Low LED
       Pause 250
       Goto mainloop
    secondled:
        high LED2
    The code works almost as it should do, but with a nice twist. When launched, if I press the button for the short period, the 2nd lend comes on and 1st one continues to blink, as it should do. However, if I press the button for a bit longer time, or press it 2nd time, the 1st led stops flashing!
    What is the reason?
    Also, I don't like that button should be handled in the loop with all my delays. Say I have somewhere in the code statement: pause 2000. This means, that even if I press button, I have to wait 2 seconds for software to react for it? is there a workaround for that? For example, on ZX Spectrum, if any key was pressed, the pause command, regardless of it's parameters, was terminated and next step executed immediatelly. Is same feature available here?
    Default Re: Strange problem with button command and loop
    What is interesting, in about a half minute, the led starts to flash again !
    The jump from a BUTTON command is essentially a GOTO, not a GOSUB.
    So from the "secondled" routine you should GOTO mainloop, not return.
    And, assembly language interrupts can be used to immediately respond to events, even if a PAUSE 2000 is executing.
    Jan 2012
    Grid EN19MV
    I don't particularly like the BUTTON command, I prefer to check it and debounce it myself.
    As to the pause, instead of PAUSE 2000, do this instead:
    FOR COUNTER = 1 TO 2000
            PAUSE 1
            ***check for button press here - if pressed EXIT***
    NEXT COUNTER
    That way, you are checking every millisecond for a button press. Of course you can adjust this to check as often or seldom as you like.
    Hope this helps,
    Andy
    -Stephen Hawking
    Thanks a lot, I've fixed it now. But I think there's a flaw in compiler. Any normal compiler, when see "RETURN" command without GOSUB, should pop up an error "RETURN without GOSUB"
    I have another question. From PBP examples, I've learned how to interact with multiple buttons. But how to set "action" running only when button is being pressed and hold?
    This is an example code:
    chk1:
    PAUSE 25  ' Pause once for each loop
    ' Check Button 1 (Skip to 2 if Not Pressed)
    BUTTON FOCLBN, 0, 40, 5, B1, 0, chk2
    TOGGLE LED1 ' Toggle LED if pressed
    chk2:
    ' Check Button 2 (Skip to 1 if Not Pressed)
    BUTTON FOCRBN, 0, 40, 5, B2, 0, chk1
    TOGGLE LED2 ' Toggle LED if pressed
    GOTO CHK1
    here the TOGGLE command toggles the status of the led. So instead of toggle, I can use HIGH LED1, HIGH LED2? but what will make LEDs low, when buttons aren't pressed?
    Sure, I can insert LED1 low, LED2 low in the code, but this will cause blinking led when pressed a button, not the steady on.
  1. Button command question
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 08:44
  2. Button command
    Last Post: - 29th January 2009, 02:23
  3. Button command explanations
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 26th October 2006, 15:34
  4. How to use BUTTON command right?
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 14th December 2005, 06:54
  5. Serin2 and Button command
    By ero in forum mel PIC BASIC Pro
    Last Post: - 1st March 2005, 08:46
