AT45 Flash problems
Results 1 to 7 of 7
    Bieli's Avatar
    Bieli Guest
    Default Did You solve this problem?
    Hello.
    I have simillar problem. Write and read to/from buffers work fine but when I transfer data into main memory I only have correct first byte and all others are FF. This problem is always on all pages.
    Thanks for help.
    Chris Mayhew's Avatar
    Chris Mayhew Guest
    Hi
    I just found this url which might be of interest.
    http://www.compsys1.com/workbench/AT45DB/at45db.html
    It provides some test code to read/write to the AT45 part, though I haven't tried it. Nor do I know anything about this website, I just "found" it.
    Chris
    hi there
    Can you please tell me what circuit you used to sort out the voltage level between the 5v of the pic and the 3v of the at45
    If I am reading the DATASHEET correctly, the device runs at the low voltage but...
    from the DATASHEET
    All Input Voltages
    (including NC Pins)
    with Respect to Ground ...................................-0.6V to +6.25V
    You could use voltage divider made with resistor or much fancy level converter circuits, ICs, or run the whole thing @3v
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by Andre_Pretorius View Post
    hi there
    See response to your other post.
  1. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 14:51
  2. Replies: 2
    Last Post: - 8th February 2009, 06:10
  3. Replies: 4
    Last Post: - 4th January 2008, 00:41
  4. 18f452 Problems
    By mglazer in forum mel PIC BASIC Pro
    Last Post: - 26th October 2005, 05:15
  5. HSEROUT Problems
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 00:17
