Hserin Syntax
Results 1 to 7 of 7
Thread: Hserin Syntax
    Apr 2012
    Ptolemaida
    Post Hserin Syntax
    Hello there Im working with a project and using the Hserin command is my final Step to finish it ( i need PC-MCU communication on background ).
    Im using PIC18F26K22 it's kind new controller but so easy to work with and so good.
    I have made C7 input and C6 output from TRISC register (C6/C7 = TX1/RX1)
    Communication Configs on laptop are
    Baud = 9600
    Parity = No Parity
    ByteSize = 8
    StopBits = 1
    DEFINE OSC 32
    DEFINE HSER_BAUD 9600 'Hser baud rate
    DEFINE HSER_CLROERR 1 'Hser clear overflow automatically
    DEFINE HSER_SPBRG 25 'Hser spbrg init
    DEFINE HSER_RCSTA 90h 'Hser receive status init
    DEFINE HSER_BITS 9 'Hser Use 9th bit for parity
      hserin [str rec\10]
      for i=0 to 10
        hserout [rec[i],13,10]
      next i
    This is the part of the code that i use Hserin and Hserout (to see if what's pic is taking are correct )
    Can you help me ?? Do i have wrong syntax ?? or Wrong Defines ?? I just got tired today for searching ways to make EUSART work
    Default Re: Hserin Syntax
    One thing is that you claim to have the laptop set to no parity but the code is setup for 9 bits. I'd remove the DEFINE HSER_BITS 9.
    Also, you're receiving a string of 10 bytes but you're sending 11 bytes (+13,10). Shouldn't prevent it from running though.
    Then I'd do a simple HSEROUT["Program Start",10,13] before entering the Main loop - just to see if the USART is alive and the connection is OK.
    Apr 2012
    Ptolemaida
    Thank you a lot Henrik for the advises ill work on it when i get back from college.
    Apr 2012
    Ptolemaida
    Hello Henrik, I got back home and did run some tests. I found what i did wrong !! I did put wrong defines.
    The only defines a simple HSEROUT/HSERIN needs are:
    DEFINE HSER_TXSTA 20h 'Hser transmit status init
    The thing that put me through trouble was that
    DEFINE HSER_BAUD 9600 and DEFINE HSER_SPBRG 25 does the same thing, they set the BaudRate and u can't use them both (what i did !!) :P
    Mistakes on pics can sometimes drive me crazy !! Thank you for your reply
    Regards, Kostas
    Apr 2012
    Ptolemaida
    Regards, Kostas
    Oct 2011
    Hi
    When using the PIC USART the Tx pin should be set to INPUT, not output as you would expect.
    See PIC 18F2x/4xK22 datasheet page 270 section 16.1.1.7
    Phil
    Apr 2012
    Ptolemaida
    Hey phil, i just read page 270. It's true what you said but it seems to work both ways. I think Hserout/Hserin sets TRIS register automatically.
    Regards Kostas.
  1. Syntax error
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 25th February 2013, 23:37
  2. syntax error
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 21st February 2010, 21:06
  3. Need help with I2C syntax problem?
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 19:11
  4. Serial LCD syntax help
    Last Post: - 27th February 2007, 04:37
  5. IF..THEN syntax
    By scaenix in forum mel PIC BASIC Pro
    Last Post: - 20th February 2007, 12:10
