Setup port pins into an array
Results 1 to 22 of 22
    Feb 2012
    PERTH AUSTRALIA
    Default Re: Setup port pins into an array
    using hendric example as base i know repeating the code for each port group and offset it will work , but its not a good way to code for many port groups using the same code , need a nice way to point to the i/o pin groups,
    A_PortOffset VAR BYTE
    B_PortOffset VAR BYTE
    C_PortOffset VAR BYTE
    For T = 0 to 2
      LOOKUP T, [0,2,3], A_PortOffset
      FOR Cycles = 1 TO PulseCnt
        PORTA.0 [A_PortOffset] = 1
        PAUSEUS 100
        PORTA.0 [A_PortOffset] = 0
        PAUSEUS 200
      NEXT Cycles
      PAUSEUS 350
    NEXT T
    T= 0
    For T = 0 to 1
      LOOKUP T, [2,5], B_PortOffset
        PORTB.0 [B_PortOffset] = 1
        PAUSEUS 100
        PORTB.0 [B_PortOffset] = 0
        PAUSEUS 200
      NEXT Cycles
      PAUSEUS 350
    NEXT T
    T= 0
    For T = 0 to 3
      LOOKUP T, [0,1,3,5], C_PortOffset
        PORTC.0 [C_PortOffset] = 1
        PAUSEUS 100
        PORTC.0 [C_PortOffset] = 0
        PAUSEUS 200
      NEXT Cycles
      PAUSEUS 350
    NEXT T
    Surely THIS can't be for the 12F683 can it?
    Anyway, if you open up the datasheet for the actual PIC and look memory map you'll see (always doublecheck !) that all the Port registers are consecutive in memory. This means that if you, for example, do PortA.0[14] = 1 you'll actually set PortB.6 because PortB.6 is 14 bits "away" from PortA.0 - pretty cool.
    For i = 0 to 8   ' 9 output
      Lookup i, [0, 2, 3, 10, 13, 23, 24, 26, 28], PortOffset
      PortA.0[PortOffset] = 1
    NEXT
    Again, make sure you check the datasheet for the actual PIC!
  1. Pointers To Port Pins ?
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2009, 21:38
  2. Variables and port pins
    By PeterReed in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 15:01
  3. Custom array of pins
    By bmagistro in forum mel PIC BASIC Pro
    Last Post: - 29th March 2009, 00:15
  4. Array of pins
    By The Master in forum General
    Last Post: - 2nd December 2007, 01:21
  5. Port A pins
    By Eric123 in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 04:25
