Diference between PK3 and production programmer
Results 1 to 12 of 12
    Sep 2009
    Default Diference between PK3 and production programmer
    I bought an PICkit 3 few years ago. And now for the first time I see note: The PICkit 3 In-Circuit Debugger/Programmer is NOT a production programmer. It should be used for development purposes only.
    I used for low volume production programming.
    What difference is between PK3 3 and some production programer? Every PIC programmed with PK3 3 works for years without any problem.
    Why I shouldn't use PK3 as production programmer?
    Default Re: Diference between PK3 and production programmer
    Well, I really do not know. I have PK2, PK3, ICD3 and an Elnec PikProg+ and using all of them. All are working great either for development or for production.
    The only difference I see is the price!
    Oh, and the speed of the the Elnec, being ... slower although a production programmer...
    Of course there can be no difference in "quality" of actually programming the part, either it gets the device programmed or it doesn't.
    I guess what they mean is that the hardware and software may not be suited for automated programming or gang-programming in a "real" production environment doing thousands and thousands of "cycles" per day. If you're doing "bench production" I'm sure it works just fine. After all, the PTG-function is quite nice for repetitive flashing of the same firmware (it's just too bad that the PK can't be powered from the target when using it).
    Now that I come to think more about it, the PK has this cheap pin head connector, that I suppose it may have a shorter life that other types of connections.
    On my Elnec, I use the ISP connector with a spring type needles to get in contact with PCB pads of the ICSP connections. These needles have very sharp ends and make very good contact with the pcb. And they are easy to change with spares. You just pull them out and replace with new ones.
    Unfortunately I do not know the english term to help you find them. I got them from the local market.
    Also made an adapter and use this needles with PK2, 3 or ICD3.
    They're usually called Pogo-pins.
    Thnaks Henrik. It was impossible to find this! Strange word...
  1. PCB low volume production
    By boban in forum Off Topic
    Last Post: - 19th May 2017, 00:22
  2. PCB low volume production
    By sales5 in forum Adverts
    Last Post: - 29th November 2012, 03:43
  3. LED production line from Chinese supplier
    By glichn in forum Adverts
    Last Post: - 13th May 2012, 05:00
  4. Pic programming in production line
    By sinoteq in forum General
    Last Post: - 12th October 2005, 17:18
  5. Time diference in microseconds
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 14th March 2005, 08:25
