Question regarding hardware serial and GPIO
Results 1 to 6 of 6
    Apr 2007
    Default Question regarding hardware serial and GPIO
    Hello,
    I am receiving some serial data using HSERIN on a 16F88. I don't need to TX any data. Can I use RB5 (the UART TX pin) as GPIO or is it locked to serial TX function once the SPEN bit is set?
    Andy
    Default Re: Question regarding hardware serial and GPIO
    Have you tried disabling TX function and blinking an LED on that pin?
    Apr 2007
    Pennsylvania, USA
    I have never tried it with a 16F, but with 18F parts I could not make use on the other USART pin when only one was needed. I may have been setting something up wrong though. Best just give it a try.
    Shawn
    Apr 2011
    Kent, UK
    When you enable SPEN it takes over both pins as you suspected.
    Apr 2007
    Thanks for the replies. The UART TX pin cannot be used fro GPIO in this case.
    Andy
    USA - Arizona
    From my experience, you can use the TX pin as an input. This same experienced is shared and discussed on the Microchip forum. However, I don't think you should do it if it can be avoided. Again, I have some prototypes which use it that way and they work without issues; but it seems like undocumented (likely unsupported).
  1. 12F683: I change GPIO.5 but GPIO.0 also changes...why?
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 4th December 2012, 17:09
  2. Replies: 1
    Last Post: - 29th February 2012, 09:37
  3. OT: Hardware question
    By PlantBob in forum General
    Last Post: - 20th January 2011, 22:15
  4. Hardware PWM Question?
    By jhorsburgh in forum General
    Last Post: - 18th August 2008, 03:07
  5. Hardware Question
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 15th August 2008, 00:08
