Variable to ports
Results 1 to 7 of 7
    Default Re: Variable to ports
    Yes of course but then you are actually executing code which writes each bit to the individual port pins.
    Each output is written sequentially, they are not all written simultaneously which the OP asked about.
    But there's no way around that as far as I know.
    here is an "exemplar" code you may glean some use of, it is for a pic16f690 demo board
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
    I VAR BYTE
    LED  var byte
    TEMP var WORD
    OVERFLOW VAR WORD
    Relays  VAR BYTE : Relays = 0
    'DEFINE ADC_BITS 10      ' Set A/D for 8-bit operation
    'DEFINE ADC_CLOCK 3      ' Set A/D clock Fosc/8
    'DEFINE ADC_SAMPLEUS 50  ' Set A/D sampling time @ 50 uS
    temp = 0
    OVERFLOW = 0
    serout porta.0,2, [$FE,1,"Loops ",# temp," "]
    ADCON1 = 0
    ANSEL  = 0
    portc = %00000000
    TRISC = %00000000
    ;LOW portB.7
    ;MyPort var byte
    'ADCIN 0, TEMP
     myPort var bit[8]
     Portc.0 = MyPort[0]
     Portc.1 = myPort[1]
     Portc.2 = myPort[2]
     Portc.3 = myPort[3]
     Porta.1 = myPort[4]
     Porta.2 = myPort[5]
     Porta.3 = myPort[6]
     PortB.7 = myPort[7]
    'random temp
     'myPort = %00000000
     TrisA = %00000000
     TrisB = %00000000
     Trisc = %00000000
    'FOR led = 0 to 4 + 1
    pattern var byte
    index var byte
    'Pattern = %11111111
    'Pattern = %00001111
    FOR index = 0 to 19
    ;MYpORT = MYpORT + 1
    LOOKUP index,[%00000000,%00000001,%00000010,%00000100,%00001000,%00010000,%00100000,%01000000,%10000000,%00000101,%11111010,%00000101,%11111010,%00001001,%00000110,%11111111,%11111001,%11111111], pattern
        'pattern = (pattern >>1)
       portc = ~~Pattern   'turn portb.0 on or off based on whether the bit is 0 or 1
     ;Portc.0 = MyPort[0]
     ;Portc.1 = myPort[1]
     ;Portc.2 = myPort[2]
     ;Portc.3 = myPort[3]
     ;Porta.1 = myPort[4]
     ;Porta.2 = myPort[5]
     ;Porta.3 = myPort[6]
     ;PortB.7 = myPort[7]
        ;2 bitwise NOTS 1st not changes T/F to Pattern and second inverts value
        ;PORTC = Pattern is a T/F statement the ( ! ) changes it to ENGLISH :D
        PAUSE 300
    NEXT index
    temp = temp + 1
    serout porta.0,2, ["Loop ",# temp," "]
    IF TEMP >= 65535 THEN
    OVERFLOW = OVERFLOW + 1
    IF OVERFLOW >=1 THEN SEROUT PORTA.0,2,["OVERFLOW ",#OVERFLOW," "]
    PAUSE 5000
    'TEMP = TEMP / 5
    'pause temp MAX 2
    'portc = portc << 1
    'TRISC = I
    'next led
    'FOR led = 0 to 3 + 1
    'pause temp
    'portc = portc >> 1
    'next led
    The code listed above has lots of unimportant stuff in it as I use it to test snippits the important part is portc = ~~Pattern 'turn portb.0 on or off based on whether the bit is 0 or 1
  1. Adding Ports status to a variable
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 20th March 2013, 22:05
  2. Need two SDA SCL ports
    Last Post: - 26th November 2010, 16:43
  3. activating i/o ports according to variable value
    By Picman in forum mel PIC BASIC Pro
    Last Post: - 29th July 2010, 13:55
  4. accessing ports pins using an index variable
    Last Post: - 19th March 2008, 20:36
  5. One variable made up of another variable
    Last Post: - 1st September 2007, 00:18
