PBP has default set of CONFIG settings for each individual device which it uses if you don't "override" via the #CONFIG/#ENDCONFIG directives (see the manual for details). To find out what default CONFIGs PBP is using for the particular device go to your PBP3 installation folder, open the DEVICE_REFERENCE folder and open the .info file for your particular device - everything is described there (they are plain text files).
When compiling make sure you use the Compile button (or F9), don't use the ICD Compile.
